Old 01-30-2016, 02:35 AM   #1
Dodge68charger
How do i tell if frame c10/c20
How do i tell if my 1969 truck frame is a c10 or c20. The vin says 1/2 ton but its got leaf springs in the back. Does that matter. Thanks
Dodge68charger is offline   Reply With Quote
Old 01-30-2016, 03:11 AM   #2
Aus69c20
Aus69c20's Avatar
Re: How do i tell if frame c10/c20
I don't know how you can tell the differences. but both c10 and c20's came with coil springs and I think leafs were optional.
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
Old 01-30-2016, 08:38 AM   #3
bigdog55
bigdog55's Avatar
On chevy the leaf springs were optional and on GMC the trailering arms were optional.
Brian
bigdog55 is offline   Reply With Quote
Old 01-30-2016, 10:49 AM   #4
The rear cab mounts are located lower on the fame than 1/2t, on 2wd. C/10s are unique in that area
Old 01-30-2016, 10:59 AM   #5
'68 Newtricks
'68 Newtricks's Avatar
yep, the rear cab cushion is about 3-4" tall on 3/4 2wd. The 1/2 2wd is about 1.25". I don't know anything about 4x4, never had.
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 01-30-2016, 11:41 AM   #6
57taskforce
All about them K’s
57taskforce's Avatar
4x4 uses the same rear cushions as C/20-30.
Tyler
57taskforce is offline   Reply With Quote
Old 01-31-2016, 01:48 AM   #7
'68 Newtricks
Also, I noticed the studs that hold the upper A-arms is 1/2" on the half ton while the 3/4 ton uses 9/16" studs.
'68 C10 SWB
'85 K30 Blazer
Old 01-31-2016, 10:13 AM   #8
snipescastle2
snipescastle2's Avatar
Talking Re: How do i tell if frame c10/c20
I believe there are extra braces on the cross members also.
Ben
snipescastle2 is offline   Reply With Quote
Old 01-31-2016, 11:57 AM   #9
Boog
laying low
Boog's Avatar
The frames are also different thicknesses between 1/2, 3/4 and 1 tons.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
