Core support bushing washer rusted away.
While under my 86 C20 yesterday I noticed the right front core support bushing and washer rusted away. I had replaced a rusted out battery tray assembly last summer, while the engine was out. The inner fender wasn't rusted through. It did have surface rust. I treated it and repainted.
Now can I get away with just replacing just the one bushing and bolt & nut plus washers ? The other cab mounts and bed mounts have no rust at all. The rubber shows some dry rot cracks. Which I would say is normal for the year of the truck. The truck has lived in the south all its years, still has its paint underneath. Or use the old bushing with new hardware ? Thanks Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
Re: Core support bushing washer rusted away.
I would replace them in pairs. Just so you would see the difference (slant)from the front
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
The more I think about it, replacing them all seams right.
Ken
