Old 01-30-2016, 06:13 PM   #1
blazercrazy70
blazercrazy70's Avatar
Who used dirty dingo sliders
With the dirty dingo sliders do use the engine stands you already have and use same style motor mounts
blazercrazy70 is offline   Reply With Quote
Old 01-30-2016, 09:06 PM   #2
Zoomad75
K5Camper
Zoomad75's Avatar
Re: Who used dirty dingo sliders
I used them on my swap. They take the place of the engine side brackets on the original small block. They mate up to the stock stands and motor mounts on the frame. I went with poly mounts as the aftermarket replacements in rubber are junk and will tear out shortly. I don't want to have to replace them again later.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 01-31-2016, 05:57 PM   #3
jweb
jweb's Avatar
I used them also. You can use your same mounts and stands, but I upgraded to the poly mounts too.
Just remember the Dirt Dingo mounts will raise your engine 1/2".
jweb is offline   Reply With Quote
Old 01-31-2016, 06:26 PM   #4
72MARIO
72MARIO's Avatar
So would the hummer or hot rod oil pan work well with these mounts ? I hope they dont mess up my pdriveline angles.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-31-2016, 06:36 PM   #5
jweb
jweb's Avatar
I used the GM "hot rod" oil pan on my '51 and it fits good, I'm not sure on a 72 though. Also you should be able to correct you driveline angle at the transmission crossmember.
Old 01-31-2016, 07:05 PM   #6
SBTork
Garage wrench
SBTork's Avatar
I used the Dirty Dingo sliders on my '85 Suburban and they worked really well. I'm running the GM "hot rod" oil pan and have no clearance issues.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 01-31-2016, 07:45 PM   #7
72MARIO
72MARIO's Avatar
I am out of room for lifting because of the gearvendors Od. Its going to hit the floor if I lift it up any higher
Adam. Does the pan sit above the bottom of the front crossmember ?
2005 TAHOE DD
Old 01-31-2016, 09:51 PM   #8
mattcrp1
mattcrp1's Avatar
I used DD sliders on 76. It sits right were it should. I used factory 76 motor mounts. I have a 4.8l with a truck oil pan that sits 1.75" below the cross member. I am most likely going with the cts-v oil pan as it appears to be just a little over 2" shallower than the truck oil pan.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 02-02-2016, 12:15 AM   #9
SBTork
Garage wrench
SBTork's Avatar
It sits just a hair below the front crossmember. I wanted it up a little higher ideally but I know the lower control arms will hit the ground before the front crossmember will so I figure I'll be ok. That and I'm on air so I can always lift it if i'm on rough roads.
-Adam
Old 02-02-2016, 09:20 PM   #10
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Here are the dirtydingo engine mounts on Zoomad75’s K5 with a 5.3L. Hard to see but you get the idea....they did fit nicely. I found it easier to leave off the exhaust manifolds so the mounts could be left loose in order to slide them around for adjustment. Once the engine was mated to the transmission and sat down on the engine mounts I tightened up the DD mounts to the engine. Pretty nice pieces.
I haven’t seen it mentioned here yet but on a 67-72 the frame engine tower brackets would need to be changed to the 73-87 design in order to use the clamshell engine mounts.
DirtyLarry is offline   Reply With Quote
