Old 01-30-2016, 06:49 PM   #1
Dave K.
Dave K.'s Avatar
Removing Heater Question
After I saw the other thread on the mouse nest in the heater I decided to pull my heater out and clean it. I got all the bolts out but it would appear I have to take the hood off the clear the blower motor assy end--is that correct? It moves around no problem but is hung up on that end by the hinge.
Also, do they make the duct which presses against the firewall?
Thanks, Dave
Dave K. is offline   Reply With Quote
Old 01-30-2016, 10:10 PM   #2
swamp rat
swamp rat's Avatar
Re: Removing Heater Question
Removing the hood is best but some have propped up the hood and pulled the hinge, i wouldn't do that myself. There is suppose to be a bolt that requires pulling the inner fender well too i believe.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-31-2016, 12:14 AM   #3
Dave K.
Dave K.'s Avatar
Thanks, I was able to get the nut on the bottom without pulling the inner fender luckily--getting it back on is another challenge.... Will pull the hood.
Old 01-31-2016, 09:10 AM   #4
1968aj
I just changed my blower motor. pulled the bolts that hold hood to inner fender on the one side. did not remove hood. I pulled the diverter box out of cab. then I took my leaf blower inserted it in hole where blower motor goes . had to clean interior when I got through but heater works good now. remove any large pieces of mouse nest before using blower to cut down the mess.
1968aj is offline   Reply With Quote
Old 01-31-2016, 09:56 AM   #5
BugzC10
BugzC10's Avatar
When I removed mine, I removed all of the hinge (next to the heater box) to fender bolts except one. (The one farthest from the fire wall, loosen it a little) Then I rotated the hinge upward / counter clockwize enough to let the heater box clear.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 01-31-2016, 10:11 AM   #6
Dave K.
Dave K.'s Avatar
Will give that a go probably. Would do the in situ cleaning but you can get a whiff of mouse when around it so best to clean it good me thinks.
Old 01-31-2016, 01:43 PM   #7
F.A.A.benny
Yea you want to clean the inside pretty good to help eliminate the mouse smell. I bead blast and clear coat the inside when I restore the boxes but you could get away with washing it with soup and water then leading it dry out.
F.A.A.benny is offline   Reply With Quote
Old 01-31-2016, 07:42 PM   #8
Dave K.
Dave K.'s Avatar
Yep, I cleaned out my Honda's heater best I could in situ many moons ago and the mouse smell still lingers every so slightly but now I'm used to it..... don't want the same with this'un.
