Old 01-30-2016, 07:23 PM   #1
BFoley
BFoley's Avatar
1966 GMC Rear Bumper Installation Issues
I am finally Getting around to finally install a repro bumper and cannot for the life of me find any good pics/resources on the placement. The truck has several bolt holes (two 1/2" and one 1 1/4") on the frame rails that were used to attached an incredibly stout one-off bumper that I removed this past summer. I purchased the bumper and brackets from LMC and nothing seems to match up.
I have scoured the internet trying to find good pictures of bracket placement but am coming up empty-handed. Whether adding a bumper to a truck without one now or back in '66, were holes required to be drilled? If not, can anyone look at my pictures and let me know what is up? Also, if anyone can snap some pics of their installed brackets, I would be beyond grateful.
Thanks,
Ben
'66 GMC K25 (305 V6, SM420) aka "Mabel"
Link to project http://67-72chevytrucks.com/vboard/s...d.php?t=698082
All gone - '66 CJ5, '69 C25, '69 C25 Camper Special, '79 C10 Big Ten/Bonanza, '84 K10 Silverado
BFoley is offline   Reply With Quote
Old 01-30-2016, 09:21 PM   #2
chevy49
chevy49's Avatar
Re: 1966 GMC Rear Bumper Installation Issues
if I remember correctly you use the large hole and the small one the bracket is at an angle.
chevy49 is offline   Reply With Quote
Old 01-30-2016, 09:56 PM   #3
DPowers
DPowers's Avatar
Does this help?
DPowers is offline   Reply With Quote
Old 01-31-2016, 05:51 AM   #4
Slow Build
Slow Build's Avatar
Hope this helps.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 01-31-2016, 09:25 AM   #5
BFoley
BFoley's Avatar
Originally Posted by DPowers View Post
Does this help?
To me, it looks like there are a few issues with my frame. I believe my truck is numbers matching, but the differences in characteristics on supplied pics is concerning me. The attachment holes on yours and other pics supplied look different from mine. Your larger hole is toward the top of the frame and mine is toward bottom. Mine doesn't have slotted/elongated holes. Your mounting holes are not on "same plane" and both of mine, on each frame rail, run parallel to rail (there is one covered in my picture by inner-frame bracket).
I greatly appreciate the pic though. Hopefully I can get this figure out.
Thanks,
Ben
Old 01-31-2016, 10:05 AM   #6
PGSigns
PGSigns's Avatar
Can we get some more info about your truck? Maybe some pics? May help figure it out. Almost looks like your frame may have been shortened.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-31-2016, 11:21 AM   #7
BFoley
BFoley's Avatar
Jimmy
I will take some pics today or tomorrow. My truck is actually a LWB.
Old 01-31-2016, 11:33 AM   #8
BFoley
BFoley's Avatar
I am also wondering if there would be any difference in the 3/4 ton and 1/2 ton frames? Mine is 3/4, not sure what the pics provided are?
Old 01-31-2016, 11:54 AM   #9
TJ's Chevy
TJ's Chevy's Avatar
If yours had the telescoping rear bumper that had provisions for a ball on the bumper then the frame will Not have the same mounting holes. I have yet to see a stock 3/4 ton with the repro fleetside rear bumper actually. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 01-31-2016, 12:16 PM   #10
cru_zn_29
cru_zn_29's Avatar
I/2 and 3/4 frames are the same for chevy. looks like your 3/4 4x4 GMC is made different i don't see the rear cross member.
cru_zn_29 is offline   Reply With Quote
Old 01-31-2016, 06:01 PM   #11
BFoley
BFoley's Avatar
Additional pictures taken and put in album to retain large image size. For now, I am trying to figure out if frame is correct. Was led to believe it was a numbers matching vehicle and everything about truck would lead me to believe it is but VIN isn't present on frame where online resources say it should be.
http://imgur.com/a/xpkfs
Old 01-31-2016, 10:07 PM   #12
Slow Build
Slow Build's Avatar
The VIN should be a little farther forward. Mine is forward of the motor mounts close to the power steering pump.
Past GM Trucks:
Old 01-31-2016, 11:30 PM   #13
Classic v6 GMC's
Classic v6 GMC's's Avatar
US built GMC trucks did not have the VIN on the frame. Our 66 gmc 3/4 4x4 does not have the holes in the frame either so my guess is that no 3/4 ton 4x4 trucks came with factory holes in the frame.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 02-01-2016, 09:11 AM   #14
BFoley
BFoley's Avatar
I read that a few times on sites last night. I am glad I cut off the huge plates that attached the one-off bumper to the frame. Since I want to incorporate the receiver/pintle hook back back onto the truck, it is looking like I am going to have to fab my own rear bumper brackets or modify the LMC ones.
Thanks to all for the help!
Old 02-01-2016, 09:12 AM   #15
BFoley
BFoley's Avatar
Does this help?
Any chance you could provide me hole locations from rear of frame? I am going to design some brackets of my own.
