View Poll Results: Which hazard button do you have?
My OEM 71ish NOT-TILT switch has the black hazard button, and I know it's original. 0 0%
My OEM 71ish NOT-TILT switch has the black hazard button, but don't know if it's original. 1 12.50%
My OEM 71ish NOT-TILT switch has the red hazard button. 6 75.00%
My OEM 71ish has a Tilt Wheel with black hazard button 1 12.50%
Other 0 0%
Voters: 8. You may not vote on this poll
Old 01-30-2016, 10:45 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Mystery hazard button for NOT-TILT 1971 C-10
My truck has the removable black with white letters button. It's two plastic pieces, a spring and mounts to the column with a small screw. I'm told by many sources the Not-Tilt turn switch should have a red button for hazards, and the one I have is for a Tilt Wheel. I've also been informed the turn switch for Tilt works for Not-Tilt as well.
To my knowledge mine has never been replaced (26 year owner). This may be one of those occasions GM used what they had available. Maybe this poll can solve another mystery.
For what it's worth, my truck was built in Fremont Ca. I don't know what year trucks had the same parts....Thanks for any input/results.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-30-2016, 11:38 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Mystery hazard button for NOT-TILT 1971 C-10
My K20 is an early model-year '72, built in Aug. 1971. I believe it was pure stock when I bought it in spring of 1977. Non-tilt with a red hazard switch.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 01-31-2016, 12:45 AM   #3
FirstOwner69
FirstOwner69's Avatar
My truck is 69ish built in Fremont in Dec., 1968. I am 100% sure the original column has a red button. I didn't vote in the poll because I wasn't sure if 71ish includes 69ish.
I don't believe the 2 piece button was available until the mid-70s. Most (all?) GM cars from the 67-72 era used a one piece screw in button. Some of those were black plastic and some (in Olds., Buick, etc.) were chrome steel.
FirstOwner69 is offline   Reply With Quote
Old 01-31-2016, 01:00 AM   #4
71CHEVYSHORTBED402
From what I understand from a very good source, the black was original for tilt. That's not to say he means the same as what I've got. I can't say for what years exactly, which is another reason for the 71ish. So if 69ish is the same as 71ish, feel free to vote.
I need a new switch. Leaning toward the red. Incidentally, it's really a three piece isn't it, excluding screw? Mine is like this or close: http://www.ebay.com/itm/New-Nos-GM-H...9TDjvu&vxp=mtr
Old 01-31-2016, 01:09 AM   #5
FirstOwner69
Probably 4 piece... 2 plastic pieces, screw and spring. Right? I have rescued 6 tilts, 3 truck, 2 van and 1 RV. I think they all have the multiple piece buttons. So, you may be right there. I've replaced the button for the tilt I put in my truck in my truck with a chrome button just because they are cool. The multi piece buttons are like the eBay listing.
EDIT: If this eBay listing for the chrome button is correct, it appears the chrome button was used in some cars from 67-72.
http://www.ebay.com/itm/1967-72-GM-H...FWEr26&vxp=mtr
Old 01-31-2016, 01:23 AM   #6
leddzepp
Moderator
leddzepp's Avatar
Original 1971
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 01-31-2016, 01:25 AM   #7
leddzepp
Moderator
leddzepp's Avatar
Van hazard switch
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 01-31-2016, 01:42 AM   #8
71CHEVYSHORTBED402
Cool. All these years I've been driving a van, thought it was a truck. Yep, mine is the same. Can't tell what angle that is. Mine sits 3 o'clock. Imagine all our trucks do.
Yep First, it's four piece counting screw.
Old 01-31-2016, 01:49 AM   #9
FirstOwner69
ledzepp's pictures look like a tilt. This eBay link seems to confirm the tilts also had red buttons.
http://www.ebay.com/itm/1969-1972-Ch...FUkmvV&vxp=mtr
