Old 01-30-2016, 11:15 PM   #1
wilkin250r
wilkin250r's Avatar
Sloppy steering, exact details?
I'm getting ready to upgrade all the components in my steering system in an effort to fix my problem of wandering all over the road. This first go around will be all the budget fixes, which rules out a steering box rebuild/replace or crossover steering. I'll do the tie rod ends, drag link ends, spring bushings, and the rag joint (I'll probably do the jeep steering shaft fix. For those searching this in the future, the details can be found here:https://www.youtube.com/watch?v=H9C4RdvjPNQ )
So let's talk about the exact details, because this is new territory for me. Are the tie rod ends and drag link ends the same? Is there a brand or style better than another? Any issues I need to look for?
Bushings for the springs: Am I looking for rubber or polyurethane? I would imagine the poly to be harder, less likely to flex. That sounds bad and noisy for cab mounts, but I don't see a downside to spring bushings.
As it sits now, my tie rod ends are the only thing that really look "bad", but I'm going to change the other components also. I'm thinking my whole problem isn't just one thing, it's a combination of many loose tolerances and worn-out parts. I'll probably brace the frame with a bracket from Offroad Design while I'm at it, and if these issues don't fix my problem, I'll rebuild the power steering box, and maybe the knuckles.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 01-31-2016, 02:13 AM   #2
bilfman
bilfman's Avatar
Re: Sloppy steering, exact details?
The poly bushings and tie rod ends will make a world of difference. Start there, my guess is that will set you straight from the info provided, that is if you have power steering .
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 01-31-2016, 02:31 AM   #3
72shorbox
Use Moog parts for your tie rod ends and ball joints, they are quality and will last
72shorbox is offline   Reply With Quote
Old 01-31-2016, 02:44 AM   #4
wilkin250r
wilkin250r's Avatar
Tie rod ends are falling apart (first picture), but my drag link ends still look good. And not just by appearance, I don't notice any significant play in them as I move the steering back and forth. But I'll replace them anyways.
Old 01-31-2016, 10:25 AM   #5
KrazyRay
KrazyRay's Avatar
Did you see any play at the pitman arm to the steering box? There is also an adjuster on top of the steering box if you have play in the box.
KrazyRay is offline   Reply With Quote
Old 01-31-2016, 11:37 AM   #6
MikeB
MikeB's Avatar
I couldn't agree more. Over the years I've seen problems with cheap "no name" parts, such as cracked ball joint grease boots right out of the box, improperly machined threads, and even a pair of tie rod ends that wouldn't take grease -- and no, it wasn't the zerk fittings. On the other hand, I've never had a problem with Moog parts, regardless of where they are made.
On another note, have you checked the front end alignment? Not enough caster could cause wandering, and that might also be true of not enough toe-in. I have to think that your very large tires might amplify any misalignment conditions, and may even require non-standard specs. (???)
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-31-2016, 12:04 PM   #7
hatzie
Moderator
hatzie's Avatar
Ditch the rag joint and factory shaft. You can either use an XJ shaft or build your own with a new Borgeson telescoping shaft and Borgeson U-Joints. Borgeson also sells complete drop in U-Joint steering shafts for the 73-91 squares. Look a the prices and decide for yourself.
I'd replace the steering damper with a good quality unit.
Urethane spring bushings will not make the ride harsher than it already is. Use em. My 4WD trucks ride like a truck. Don't care. That's what they are.
I agree... Get MOOG swivel ball joints and tie rod ball joints. They're worth the price.
The GM 4WD Pitman or Steering Box arm is a socket not the ball joint. It connects to the back of the LH knuckle with a tie-rod assembly reminiscent of an automobile. Very easy to replace. No monkeying with the steering box to Pitman arm relationship is neccesary.
I did find it a little annoying that GM didn't thread a Tie-rod end onto or into the center link... instead they made the center link and LH tie rod end one long obnoxious expensive piece.
Make sure the frame behind the steering box is not cracked. You can add some very simple gussets to reduce the bending force applied to the frame horn by tying the steering box mounting bolts to the front frame crossmember. There are also weld-on stamped plates that will reinforce a weld repair of an already cracked frame horn.
Brace installation on undamaged frame. Four Wheel Drive Magazine.
Offroad Design makes the braces and the reinforcing plates. If you're handy you can fab your own braces but they're fairly inexpensive to buy when you factor in your time and you will not fab stamped reinforcing plates.
http://www.offroaddesign.com/catalog/steeringkit.htm
Don't adjust the steering box. If it's loose replace it.
AGCO Saginaw power steering article.
From the article --->"Many people have been mislead into thinking the adjusting nut on top of the steering gear is to remove slack. This adjustment is meant to set the initial lash, between the gears, when the box is built. This adjustment will NOT remove slack. Tightening this adjustment will force the gears together and cause them to bind. Ironically, binding gears make steering far more difficult and actually feel even more loose."
Download the Power Steering textbook from my manuals link and read through it. It's a GM Service Training group textbook that includes information on the Saginaw steering box and the power steering pump.
Flush out the power steering a couple times with cheap ATF and then re-fill with GM power steering fluid or just replace the power steering pump. I'd put a real Magnefine filter in the return line with Fuel Injection Clamps. If the return line is soft replace it with SAE J189 hose.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 01-31-2016, 09:01 PM   #8
1redbowtie3
1redbowtie3's Avatar
Good info, thanks for taking the time to post it ..
1985 K20 4spd
1978 K20 4spd
1redbowtie3 is offline   Reply With Quote
Old 02-01-2016, 12:21 AM   #9
enaberif
Jeep shafts don't work on 76 and older trucks due to different power steering boxes
enaberif is offline   Reply With Quote
Old 02-01-2016, 12:39 AM   #10
wilkin250r
wilkin250r's Avatar
This truck is a Frankenstein of many different years and parts. However, the frame VIN indicates a 1979, and the majority of components seem to match. I'd give it a 90% likelihood the steering box is 1979.
Old 02-01-2016, 01:35 AM   #11
slotard
Interesting, I didn't realize that. I swapped a steering column from a newer truck (don't remember year but I switched from push to pull ignition or the other way around, I forget), I thought I used the shaft from the newer column.
I take it I'd need a steering box from a newer truck to make that work?
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 02-01-2016, 01:47 AM   #12
wilkin250r
wilkin250r's Avatar
I don't see any play in the pitman arm. What I do see is a little bit of frame flex at the steering box, but I don't see any cracks in the frame so far.
Not only are my tires large, but my rims have something like a 2-inch backspace, they have a REALLY wide stance. All that extra leverage I'm sure is a big contributing factor to my problem. I would imagine that fixing the tie rod ends and bracing the frame with the ORD kit will fix 80% of my issue.
Old 02-02-2016, 11:57 PM   #13
mattcrp1
mattcrp1's Avatar
i had to take my steering box off and found the crack in the frame, I ordered the smittybuilt frame brace that is supposed to help this. Still waiting on it so show up.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 02-03-2016, 01:10 AM   #14
Matt Man
Matt Man's Avatar
I put both the bolt in brace and welded the frame ( my frame wasn't cracked ) and the truck not only steers better, but tracks a lot better after you hit a bump on the highway. The whole front end feels way more solid now.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 02-03-2016, 02:15 AM   #15
'68 Newtricks
'68 Newtricks's Avatar
I'd pull the steering box off and check for cracks. There are tons of pictures of cracked holes or even a crack going from hole to hole, behind the box.
Find a Jeep shaft in the junkyard or get a new one from Amazon ~ $100. If you go Jeep shaft, make sure to weld the top isolater bushing solid. They tend to be super loose by the time they hit the Jyards. I wish I knew what the year break is for the Chevy columns and steering boxes. I know mid 80s stuff works
If you wheel the truck, a weld in frame brace is also a smart move. It's not just for repairs, it's also preventative.
Poly everywhere for a wheeler. For a cruiser, I'd say poly everywhere but the body and trans mount.
Moog and no, the TRE and DLE are different taper sizes. It has to be ordered correct.
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 02-03-2016, 02:22 AM   #16
hatzie
Moderator
hatzie's Avatar
I'd stay clear of the Poly motor mounts too.
Old 02-03-2016, 03:01 AM   #17
wilkin250r
wilkin250r's Avatar
As I mentioned in post #12, not only are my tires very large (40"), but they are also wide (wheels are 15" diameter, 14" wide). They also have a very small offset, which makes them stick out really far.
All this creates a huge amount of leverage acting against the steering components.
With all this force, I feel I could easily benefit from a dual-stabilizer setup. However, I think dual stabilizers are ugly. Does anybody know if I can purchase an aftermarket stabilizer (or have mine rebuilt) with significantly more damping force? Basically, can I make a single stabilizer setup as strong and effective as a dual-stabilizer?
Old 02-03-2016, 09:46 AM   #18
hatzie
Moderator
hatzie's Avatar
You can get motor home stabilizers with coilover springs.
With wide tires on that offset you should probably add the weld on plates. They'll be easier to put in before the frame horn cracks.
Old 02-03-2016, 11:08 AM   #19
slotard
Is there any downside to the bolt-in brace on a truck that doesn't appear to have any problems?
1973 C20, 350/350
Old 02-03-2016, 11:37 AM   #20
hatzie
Moderator
hatzie's Avatar
No.
