Old 01-31-2016, 01:10 PM   #1
gafiredog
wiring for dual tanks
Hey All. does anyone know the color of wiring I need to be looking for on the dual tank wiring harness for my 78 c-30. switch tank to left side, fuel gauge reads fine, and get fuel out of fuel pump. switch to right side, cant hear any sound in the change over valve mounted to the frame, and also, gauge needle goes to 3 oclock, so I have not even put any fuel in that tank. any help appreciated.
Art
1975 c-10 stepper
1978 single cab dually
1987 crewcab dually
1986 crewcab single wheel
1948 anglia- (the dixie twister super gas)
gafiredog is offline   Reply With Quote
Old 01-31-2016, 03:12 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: wiring for dual tanks
3:00 needle means there's a break between the tank to frame ground and the gauge. In order of probability.
  1. Frame ground to sender ground wire is broken.
  2. Wire from sender to tank switch AUX terminal inside the cab is cut or badly damaged.
  3. The dash switch is shot and not routing the sender signal to the gauge.
Since the valve is inoperable too... the dash switch may be shot.
The dash switch is cheap and easy to replace. Fairly easy to test too.
Check for volts at the tank valve connection stud with the engine off / ignition on and the tank switch set to AUX. If you have volts then the valve is shot. No volts means the fuse is blown or the switch is shot.
This is a graphic I made to explain the internal operation of the switch. It's a Double Pole Double Throw switch that's missing 1 terminal.
Name:  73-80 tank switch.jpg
The wiring diagrams are in my signature.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 02-01-2016, 03:04 PM   #3
gafiredog
thanks for the help, Hatzie
Art
1975 c-10 stepper
1987 crewcab dually
Old 02-02-2016, 03:49 AM   #4
Man With A Gun
Man With A Gun's Avatar
Which tank is the aux? The driver's side?
77 Chevy K20 Longbed
86 GMC C3500 Dually
07 Silverado 2500HD
All standard cabs
Man With A Gun is offline   Reply With Quote
Old 02-02-2016, 12:21 PM   #5
hatzie
Moderator
hatzie's Avatar
Depends on the year.
Old 02-02-2016, 02:12 PM   #6
Man With A Gun
1986 in my case.
86 GMC C3500 Dually
07 Silverado 2500HD
All standard cabs
Old 02-02-2016, 04:23 PM   #7
hatzie
Moderator
hatzie's Avatar
There are two different tank valves for the NL2 optioned trucks.
The 1975 - 1980 Solenoid valve, like the OP's 1978, snaps back to a rest position. The rest position is the production tank.
I've owned several single tank C/K trucks with model years between 1973 & 1979 and not all of them had a LH tank... At least one of them was a RH tank truck but I don't remember what year it was... It was Light Blue that's all I remember about it. Service, Wiring, and Parts manuals are not much help either...
1981-1991 trucks don't have Production and Aux tanks it's just LH & RH tanks. Your 1986 is one of these.
The Motorized valve retains its' position after power is removed so there's really no AUX tank.
The short answer is between 1973 & 1980 I don't know which side the production tank was on. Look at the plumbing and go from there. You can pick the tank you want to call AUX when you put the valve in just be sure the sender wiring matches the plumbing. Not very satisfying but...
Old 02-02-2016, 08:25 PM   #8
ray_mcavoy
According to the listings in the GM Heritage Center Vehicle Information Kits, the production tank was on the RH side for 1975 through 1980. And was moved to the LH side for 1981 - 1991.
You're right, as far as the switch & valve setup is concerned, it's just LH & RH tanks in those years. So the terms production and auxiliary are really only useful for describing where the tanks were located when making comparisons between trucks with & without the NL2 option.
ray_mcavoy is offline   Reply With Quote
Old 02-02-2016, 09:03 PM   #9
hatzie
Moderator
hatzie's Avatar
Thanks Ray.
My 77, 79 & 85 had single tanks on the LH side... The 77 & 79 were third or fourth owner rigs with stake boxes. Swapping tanks from RH to LH with no bed on is not a big trick.
I think the blue truck was a 1974 or 1975 GMC with one RH tank. It was not the original bed because it had a fuel door. I owned that one in the mid 1980's.
Unfortunately the GM wiring diagrams use Production and Aux on the 70's NL2 rigs not LH & RH. Sounds like the original layout is Production = RH and AUX = LH...
