Old 01-31-2016, 01:56 PM   #1
CokeZero
CokeZero's Avatar
5 lug question
When I got my truck, the previous owner had already did a front disc and 5 lug conversion. I forgot to get the info from him and no longer have his contact info.
How do I find the lug pattern of which 5 lug he used?
When it comes times that I need new rotors what do I tell them its for?
Also brake pads, when I need to get some, what vehicle do I tell the parts house they are for?
Thanks in advance!
1969 Çhevrolet Ç10 Çustom 350 V8
CokeZero is offline   Reply With Quote
Old 01-31-2016, 02:09 PM   #2
hugger6933
Re: 5 lug question
If it is an aftermarket part the company name may be stamped in them with a part number. However if they are just plain ol GM you will need to know if they are 71-72 or 73-87 types. the best way for that would be a side by side comparison at the parts store. Jim
hugger6933 is offline   Reply With Quote
Old 01-31-2016, 05:47 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 5 lug question
Pictures would help a lot.
GM has basiclly 2 wheel stud patterens.
5 on 5 which is stock truck wheels.
5 on 4 3/4 which is for cars.
One of these will help a lot if your going to a junk yard to look for wheels.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-01-2016, 12:14 PM   #4
67 cst swb
67 cst swb's Avatar
Re: 5 lug question
As far as brake pads and calipers go... The brake pads and calipers are the same for 71-72 & 73-79 trucks.
Only difference would be upper and lower bushings and tie rod ends. But all the brake stuff is the same.
My Trucks:
Current Project
1968 Chevrolet Short Wide Box 327 TH400 9" w/3.90 gears, paint will be White
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 02-01-2016, 12:16 PM   #5
67 cst swb
67 cst swb's Avatar
Re: 5 lug question
Thanks in advance!
The most commonly used disc brake conversion for your truck would be the 73-79 disc brake set up. I would start there. If it is different than that, then PM me I will get you my phone number and help you out as much as I can by asking you some questions about what you have.
My Trucks:
Current Project
