Old 01-31-2016, 08:26 PM   #1
firstgencamaros
What lowered springs?
Hoping some of you may have been in the same spot before. I have a 69 short wide that I want to sit lower than stock. 2"-3" would be fine as function is important. I want it to be a static drop with the truck level or maybe raked with the truck no more than 1" higher in the rear. I am going to tow a car trailer with it and will add air bags to it for towing assist only. The truck has a cast iron head big block chevy engine with th400 trans. I do not want to notch the rear frame. Any suggestions as to what springs to purchase would be great.
Thanks for any input.
FGC
firstgencamaros is offline   Reply With Quote
Old 02-06-2016, 12:26 PM   #2
firstgencamaros
Re: What lowered springs?
So, nobody on here has lowered a short bed with a big block? Just looking for experiences on what springs have worked for people.
FGC
Old 02-06-2016, 01:11 PM   #3
dell72
i think there is a "sticky" on this subject in the FAQ's section
dell72 is offline   Reply With Quote
Old 02-06-2016, 01:52 PM   #4
firstgencamaros
I looked, didn't see it. Got a link?
FGC
Old 02-06-2016, 03:16 PM   #5
CST10
CST10's Avatar
I went 2/3 on my BBC LWB and had to add 1" blocks to get it leveled out. I would try 2/4 drop with springs only and it should get you close.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 02-06-2016, 04:39 PM   #6
firstgencamaros
Thank you CST10. That helps. Do you have a pic of how it sits?
FGC
Old 02-06-2016, 05:32 PM   #7
68bowtie
68bowtie's Avatar
here is my 68 with 3" rear drop springs and cut front springs. not sure how much the po cut off the front but i think about 2". it's a bbc truck with a sbc in it.
Old 02-07-2016, 12:23 AM   #8
jeh
jeh's Avatar
Here's mine with ECE 4/6 static drop. I am also am running a big block engine.
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 02-07-2016, 01:04 AM   #9
gottattooz
gottattooz's Avatar
I was going to suggest the 4/6 drop. Great stance, evens out the rake without notching the frame.
- Josh
1967 Buick Special wagon
1968 Jeep Wagoneer
1958 Chevy Panel Truck
2017 Suzuki M109R
gottattooz is offline   Reply With Quote
Old 02-07-2016, 09:41 AM   #10
6" springs in the rear don't allow for hauling/towing w/o a notch. I have 4/6 on my rolling chassis. I don't want to notch, I want to haul/tow, and not sure if I want the modern level look (like the 4/6) or the classic rake (4/4). My solution is get air bags in place of rear coils. I can have it all that way. Even if I was solid on no more than 4" drop I think I'd do the bags to increase capacity if/when needed. I won't own a worthless pickup
Old 02-07-2016, 10:30 AM   #11
brad_man_72
the boat guy
brad_man_72's Avatar
Spring only 4-6 drop. No notch no bags. "Worthless pickup"
I guess I didn't get the memo.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-07-2016, 02:03 PM   #12
I knew you'd have to comment. I'm glad that combo somehow works for you. But I do know from others, and my own experience, that is too close for comfort for me and I can figure on bottoming out. I'm used to trucks I can throw anything in w/o a thought, so my little SWB will be as much of that as can be, for what I consider my car. I just meant a worthless truck is one you won't or can't haul anything in. I've seen these pictures before, so was not referring to yours.
Old 02-07-2016, 05:28 PM   #13
brad_man_72
the boat guy
I know K just giving you a hard time. Mine is bottomed out with a full tank of gas. Full length bumpstops and a ton of sidewall make it pretty tolerable. Doesn't ride much worse than my miata and better than any of the stock 3/4 tons I've driven. It is in no way right or correct but it does function pretty good.
I kept up with a buel around a 30mph corner the other day with about 700lbs in the back, after he got it straight he lost me by lane splitting but I got a chuckle out of it.
Old 02-07-2016, 05:49 PM   #14
I "used to" do a lot of bottoming out, rubbing tires, and all that and never thought anything of it. It's nice there's so much out there for suspension now. I've used the air lift auxiliary springs with leafs and the inside coil type. Is there an inside coil set-up for lowered springs or are bags in place of coils the only choice for 4"-6" lower. Not crazy about only bags.
Old 02-07-2016, 08:32 PM   #15
Boog
laying low
Boog's Avatar
Tim I believe Andy has air lift bags inside his rear coils.
Boog
Old 02-07-2016, 08:53 PM   #16
CST10
CST10's Avatar
Sure do. Here is Samson. BBC engine. 2/4 drop
MyToys:
Old 02-07-2016, 08:56 PM   #17
CST10
CST10's Avatar
Here's Goldilocks with a 3/5 drop, straight 6 silly.
It looks lower than the 2/4 on Samson but actually samsons slightly lower side by side in the front. Might be the big block weight.
MyToys:
Old 02-07-2016, 09:01 PM   #18
CST10
CST10's Avatar
Rule of thumb is lower the rear by 2" more than the front and it will be close to being level.
MyToys:
Old 02-07-2016, 09:05 PM   #19
CST10
CST10's Avatar
Nice stance. I like it.
MyToys:
Old 02-07-2016, 10:04 PM   #20
jeh
jeh's Avatar
Thanks!!!
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 02-08-2016, 02:42 AM   #21
'68 Newtricks
'68 Newtricks's Avatar
OP: If you like the ride now, why not just 2-2.5" drop spindles up front? Add 2" more for a spring drop in the rear. I would have thought spindles would be the first thing to change, especially if the drop you want is the same as spindles. Just throwing it out there.
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 02-08-2016, 09:01 AM   #22
I thought the same thing, spindles on front with stock springs.
