Old 02-01-2016, 01:25 AM   #1
62jimmy
suspension rebuild with drop?
I have an 84 front crossmember swap I am ordering rebuild parts for. I will be using 2 inch drop spindles and 1 inch drop springs in the front. Are there any specialty suspension parts that I need to use with these like pitman arms or idler arm due to the drop? or can I just use stock replacement parts for everything?
Any help would be appreciated
Jeremy
62jimmy is offline   Reply With Quote
Old 02-01-2016, 10:47 AM   #2
Hop
Re: suspension rebuild with drop?
If you are use all 84 parts, you should be ok. Doing the same on mine, using 84 everything, idle arm, pitman, linkage tie rod to tie rod. That way if you need to replace no guessing. I'm doing a 2 inch drop spindle, 3 inch drop spring in front.
Hop is offline   Reply With Quote
Old 02-01-2016, 11:35 AM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Use everything from the '84. Ball joints and tie rods are different then anything pre '72.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 02-01-2016, 07:35 PM   #4
62jimmy
Thanks for the input guys. I am planning on ordering all 84 parts, I just started to question whether any of the other parts needed to be different than stock to keep all the steering and suspension geometry correct, mis-typed also, I am only doing a 1 inch spring, for a total drop of 3 inches
Old 02-02-2016, 10:47 PM   #5
jason999
I have the same setup and I just installed 3" drop spindles and 4" drop springs on my truck. I wrestled with different ideas. I ended up keeping the old springs, because I didn't know how much they had settled. I felt like I may get new 1" drop springs, only to learn that my old springs had settled an inch.
You have to measure your rotors before you order. I have 18" wheels, with 255/55 , btw
Mine ended up exactly where I wanted it.
My spindles were $200, I think. There was an issue with the length of my brake lines. I had to work a few things but I was able to use my old brake lines.
jason999 is offline   Reply With Quote
