02-01-2016, 10:28 AM | #1 |
GM Pulse Generator for electric speedo
This a new part. They list for $129 from DD, I will take $80 shipped..
The missing piece of the increasingly popular early-GM transmission swap! With late-model GM transmissions containing an internal speed sensor outputting 128,000 Pulses Per Mile, the stock 40-tooth (40 pulse per revolution) reluctor ring provided the factory ECM with a high frequency input. The SEN-01-128 can now recreate this missing high frequency rate when converting to an older style transmission with a mechanical speedometer output. With a standard female 7/8” thread-on fitting, the SEN-01-128 fits all GM transmissions with a mechanical speedometer cable outlet. Removable weather-tight 10’ cable provides for simple installation and cable routing. 128,000 Pulse Per Mile Sine Wave signal output is direct replacement for the stock GM internal speed sensor, allowing the ECM receive the signals it needs for proper operation. Fits GM transmission models with 7/8” Male Threading, ie: TH350, TH400, 700r4, 2004r, etc. http://www.dakotadigital.com/index.c...rod/prd916.htm
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-03-2016 at 11:47 AM. |
02-01-2016, 11:26 AM | #2 |
Re: GM Pulse Generator for electric speedo
so this is not for the 4l60 then?
1967custom |
02-01-2016, 11:34 AM | #3 |
Michael - 4L60e's have a built in signal generator.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-05-2016, 12:33 PM | #4 |
bump
02-05-2016, 12:52 PM | #5 |
So this is for the LS crowd that wants to run an older model trans?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
02-05-2016, 12:59 PM | #6 |
Do you know of there is a way to T the speedo cable and still be able to retain the mechanical speedo ? I dont want to switch to a electric speedometer. I would like a vss signal for my ls swap but plan to keep my 400 and gv od setup. If there is a option to t the cable i will take it.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
02-05-2016, 03:20 PM | #7 | ||
02-05-2016, 03:47 PM | #8 |
Do you know if there is any way to split the cable and run this as well as the factory speedometer cable ?
02-05-2016, 04:08 PM | #9 | |
http://www.dakotadigital.com/index.c...rod/prd109.htm R
02-11-2016, 06:15 PM | #10 |
Bttt
02-13-2016, 12:04 AM | #11 |
Hey 72MARIO, I could've saved you the shipping costs, and picked it up.
02-19-2016, 09:26 AM | #12 |
bump
02-29-2016, 09:03 AM | #13 |
bump
03-28-2016, 10:25 PM | #14 |
bttt!
03-30-2016, 11:36 PM | #15 |
Don't know if they are still around, but taxi cabs had a splitter to run their meter.
04-02-2016, 02:49 PM | #16 |
bump
04-13-2016, 12:12 PM | #17 |
ttt
04-28-2016, 09:12 AM | #18 |
bttt
10-19-2016, 01:33 PM | #19 |
bump!
01-20-2017, 02:02 PM | #20 |
Still available?
GMC C15 -68 project: http://67-72chevytrucks.com/vboard/s...d.php?t=526059 Front/back Porterbuilt dropmember, Accuair, LS1/4L60e Chevrolet C20 -72 C20 to K10/20 conversion, LS power. |
01-20-2017, 02:29 PM | #21 |
01-20-2017, 03:38 PM | #22 |
Ok, I just need to do some research about this thing, I'll get back to you!
01-23-2017, 09:22 AM | #23 |
What did you figure out?
