02-01-2016, 11:01 AM | #1 |
71 Stepvan gear change
Been looking around and I'm having trouble finding the right series carrier. Research says we got a 3.73-4.10 gears and we're trying to go to a 3.08. I would love to put 3.08's on what I got but not sure if it will work. Thanks for any help.
02-01-2016, 12:34 PM | #2 |
Proprietor of Dale's Corner
Re: 71 Stepvan gear change
What size step van 1/2, 3/4 ton etc?
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
02-01-2016, 12:47 PM | #3 |
Half ton p10
02-01-2016, 12:55 PM | #4 |
Member #1049
A 3:08 ring and pinion will not fit on the carrier in your rear end, if your stepvan is a Chevy it should have a trailing arm rear suspension, you might just search around for 3:08 rear axle assembly out of a 71-72 Chevy pickup, a majority of them came with the 3:08 ratio and will bolt right into your P10
02-01-2016, 01:03 PM | #5 |
Are they the same width because it's bagged and pretty close as it is.
02-01-2016, 01:04 PM | #6 |
It's my wife's business vehicle btw.
02-01-2016, 09:14 PM | #7 |
Member #1049
If it is a 71 with the factory 5 lug axles, yes it is the same width as the pickups
02-02-2016, 12:00 AM | #8 |
check summit racing.com I was able to buy a3.73 that fit my 3.08 carrier and I think they sell 3.08 that will fit your carrier.
02-03-2016, 01:52 PM | #9 |
Thanks I'll check that out.
02-03-2016, 02:01 PM | #10 |
the brand I bought was Richmond gear
02-03-2016, 02:05 PM | #11 |
FYI... you may want to double check me on this... but...
I believe the wheel bolt pattern on your van may be 5 on 4-3/4" So swapping in a different rearend may lead to other changes, such as swapping your orig van housing axles back in or else a wheel change. But please double check your wheel bolt pattern as I could be wrong. Pick-ups are 5 on 5" and I think vans are 5 on 4-3/4"
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
02-03-2016, 03:18 PM | #12 |
It is in fact 5 4-3/4. I guess I'll just buy a carrier and gears since it's prolly easier and maybe cheaper than a trans swap. I got lucky with the van, came with a small Chevy pattern and discs up front.
02-03-2016, 03:21 PM | #13 |
More pics here
02-03-2016, 03:22 PM | #14 |
Our daughter loves it....no surprise.
02-03-2016, 03:42 PM | #15 |
Junior Member
Super cool P10! Did you check your bolt pattern? My '73 is 5x5.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
02-03-2016, 10:02 PM | #16 |
I did not physically but that's what I read.
