Old 02-01-2016, 12:17 PM   #1
rusty matheny
1965 c10 - frame help please
Building a 1965 c10 short bed.
Frame seems to be out of square 1/2 inch. Local frame shop says this isn't an issue on these trucks but, I am concerned .
Fairly decent hp and torque going back in ( 420 hp/torqe ) , tremec 5sd, lowered ( not bagged ) , sway bars etc.
Concerns are not as much about lining up body panels as fit and finish can be adjusted for, my concern is it pulling straight and steering correctly- really need advice from someone well experienced with these frames, proper checking, tolerances and where to look for/find issue.
Can not locate single area where frame is out, ALL cross measurements are pretty close to 1/2 inch out over every section of frame ( three x measurement areas) - it almost seems as if frame was "out" from factory.
Cannot find any apparent bends or creases in C channels.
Im just stuck , no frame shops in my area want to deal with bare frame and all seem to think 1/2 out on square with 50 year old truck is ok.
Please advise/help/direct.
Thanks ahead of time.
rusty matheny is offline   Reply With Quote
Old 02-01-2016, 02:38 PM   #2
jtrichard
Re: 1965 c10 - frame help please
Common on ladder frames ...Frame is bare now? if so put a chain and binder diagonally from two good strong points and pull it back to square...... You may need to loosen the front cross member bolts
jtrichard is offline   Reply With Quote
Old 02-01-2016, 03:06 PM   #3
rusty matheny
Have K- member out.
Just a bare frame.
Old 02-01-2016, 03:19 PM   #4
PGSigns
PGSigns's Avatar
They can be off some from the day they were made. It is more important to see how square the suspension is when you get it in.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-01-2016, 03:24 PM   #5
PGSigns
PGSigns's Avatar
If you go to the FAQ section at the top of this forum you can get lots of info. This thread may give you some insight. http://67-72chevytrucks.com/vboard/s...d.php?t=325736
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 02-01-2016, 04:53 PM   #6
Sik5chevy
Not uncommon, i have seen guys do it thereselves and i have done myself once. there are several body shops with a frame table in houston that will straighten it. Just make sure you use a reputable shop if you go that route.
Sik5chevy is offline   Reply With Quote
Old 02-01-2016, 05:48 PM   #7
jtrichard
Originally Posted by rusty matheny View Post
Have K- member out.
Just a bare frame.
You can probably pull it square with a come-along then ...There is NO X-bracing on these frames and just a light hit on a frame rail will do just what you have
