Old 02-01-2016, 01:34 PM   #1
davepl
davepl's Avatar
Speedo Gear Question, plus needle bounce
I made a few minor changes to my speedo calibration:
- New speedo warning head from unknown ratio truck
- New trans with overdrive and unknown expected rear end ratio
- Different rear end ratio
- Taller tires
So, as you can see, all bets were off. But driving by a speed sign I magically found it said 38 when I was at 36. I figure that's close enough, but would I get much closer if I did the math on the error and changed a gear?
Also, I have a tiny bit of needle bounce, like in a 2-3mph window. Anything I can do about that doesn't require rebuilding the speedo? Cable is silent and new.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-01-2016, 02:35 PM   #2
cleszkie
cleszkie's Avatar
Re: Speedo Gear Question, plus needle bounce
You might find that the speedo deviation will increase with increased speed (i.e when going 70 it will read 80 - probably an exaggeration, but you get the picture).
cleszkie is offline   Reply With Quote
