Old 02-01-2016, 02:12 PM   #1
slotard
14FF refresh
I picked up a used 14FF with the gearing and locker I want. I'll be converting it to discs before putting it under my truck (which already has a 14FF).
I'm not aware of any problems with it. That said, if there are cheap easy things that I ought to do while it's easy to access, I'd prefer doing it now to later.
Is there anything I ought to replace? Plans so far are to change the oil in it, reseal the pumpkin, and discs. Anything else?
Also, the axles appear to be RTVd to the hubs and are difficult to remove. Is my best bet a hammer and a razor blade or something? Is this a sign that a seal is likely bad or something?
I have a functional 14FF under the truck now that I can rob parts from if needed, but I'd rather not if I don't have to.
Also, any suggestions on where to get good U bolts? I wouldn't be surprised if mine are factory.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 02-02-2016, 08:34 AM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
Re: 14FF refresh
New seals, bearings and stinky goo (seriously -- does anything smell as bad as differential oil?) --
All pretty easy to do with it on the floor, not as easy when it's under a truck.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 02-03-2016, 02:27 PM   #3
slotard
Re: 14FF refresh
Any suggestions on brand for bearings/seals? Will I need a press? I've never rebuilt an axle before.
1973 C20, 350/350
