Aeroquip 6an (3/8") socketless fuel lines. 12.5' & 13' w/ extras
<<<<<<<<<<<<<<<<<SOLD>>>>>>>>>>>>>>>>>>
Up for FOR sale is a complete fuel line set for EFi & LS engine swaps. These parts would cost $209 if bought from Summit Racing. They are pre-cut and ready to install for LS swaps using aftermarket -6an lines fuel rails and a rear mount gas tank in 67-72 C10's The parts Included in this auction are.. - (1) Aeroquip FCN0620 AQP Socketless -6 AN EFi fuel line terminated with (2) 90 degree -6an fittings 13' in length. - (1) Aeroquip FCN0620 AQP Socketless -6 AN EFi fuel line terminated with (2) 90 degree -6an fittings 12.5' in length. - (1) Aeroquip FCN0620 AQP Socketless -6 AN hose , 34" section - (2) Aeroquip FCN0620 AQP Socketless -6 AN hose, 25" sections - (2) Aeroquip Socketless Hose Ends FBL1532 , 90 fittings - (2) Aeroquip Socketless Hose Ends FBL1512, straight fittings. The two main fuel lines were installed and used for approx. 100miles. The smaller sections and spare fitting have never been used. I switched to a different style of line on my project. Can be used with carb or EFi. Full Disclosure: I replaced with Teflon lines due to slight fuel odor in my 2 car garage. These lines are perfect for a vehicle outside or race car ( or for those who enjoy vintage car/truck scent) Last edited by Bowtiguy; 03-03-2016 at 02:21 PM. Reason: edit: parts still available |
Re: Aeroquip 6an (3/8") socketless fuel lines. 12.5' & 13' w/ extras
Still available, all boxed up and ready to go.
![]() Join Date: Jan 2009
Re: Aeroquip FC598-06 6an (3/8") fuel lines. 12.5' & 13' w/ extras
Will you take 75 shipped
Pulatoy |
What is the cause of the fuel smell ??
Let me know if you change your mind. My offer is is base on lines that you say give off a order already cut that I need to make fit my car and used.
Pulatoy |
#7 | |
if the lines are not PTFE ( Teflon) coated they will permeate gas smell over time.
I'm pretty sure the 100 miles of road use justifies the 60% discount from new. if not, youre welcome to buy new. AND, if you buy new, you'll get the SAME odor BECAUSE they are near new. Some are bothered by the odor, some are not. its not that MY lines are faulty, it seams to be across the board. choose for yourself. http://67-72chevytrucks.com/vboard/s...d.php?t=691463 |
$80 shipped?
edit
Sold!
