Old 02-02-2016, 10:51 AM   #1
Rusty704x4
Big Block headers?
Alright ladies and gents I am swapping a 454 in my 70 C30 I'm running a 465 with a NP205. My question to you guys is what headers are you running? Its a Gen IV 454 any suggestions or part numbers would be greatly appreciated
Rusty704x4 is offline   Reply With Quote
Old 02-02-2016, 10:54 AM   #2
IIGW
Re: Big Block headers?
camaro/chevelle work good, slight modification needed, but fit tight and high
IIGW is offline   Reply With Quote
Old 02-02-2016, 12:32 PM   #3
b454rat
I ran chevelle headers on a truck I built, only issue I had was the hyro slave cylinder. I had to shim it out to clear the primary. But they tucked nice, couldn't see them below the frame. Plus a million times cheaper than truck headers or others.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
b454rat is online now   Reply With Quote
Old 02-02-2016, 12:52 PM   #4
nvrenuf
Sanderson Headers shorties on mine. High and tight and no interference with hydraulic clutch stuff.
John
'91 Blazer, full top, bbc, 4spd, Doubler, 1 tons, 40's
nvrenuf is offline   Reply With Quote
Old 02-02-2016, 01:12 PM   #5
Rusty704x4
Awesome! Thanks guys.
Old 02-02-2016, 01:42 PM   #6
FlameOut
With the above saying Chevelle headers, I will add that I used Hedman Elites on my 67 Chevelle with big block. Fit like a glove. I personally have no experience though with these headers on our trucks
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
Old 02-02-2016, 03:10 PM   #7
ptc
ptc's Avatar
Im assuming you have a stock old RV 454 engine you are asking about only because you didnt list any performance 'enhancing' goodies to consider in your question....
With that said you can probably get away with putting any of the chinese $79 1.25" primary tube header kits available out there from any of the ebay providers.
BUT - if you want that motor to really breath and give you the performance a tuned header system should give you then you should open it up and find a good header that has the right size primary for your mods. The shorty headers and mid lengths are for a single purpose and they rob BB's of horsepower, nuff said. I wouldnt put anything less than 1 7/8" primary on a 454 to begin with, no matter what type head you have. These are readily available. If you want to go 2" primary then you have a bit less to chose from. But Patriot is a brand that has them in 2".
2 1/8" and 2 1/4" are typically custom but check out Mad Dog and Mikes
http://maddogheaders.net/products/chevy
http://www.mikesfabshop.com/header-sizing.html
Good luck to ya.
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 02-02-2016, 03:44 PM   #8
FlameOut
Also, be sure you have access to all of the plugs, the starter, and the oil filter. Before I switched to the Hedman Elite, I had some cheap Summit Racing headers. I had to losen the headers just to get the oil filter off. Also, it looked as if removing the starter would have been a bigger challenge. I have easy access to the above mentioned items with the Hedmans. Just something to consider
1967 Chevelle SS
Old 02-02-2016, 05:15 PM   #9
Rusty704x4
Thanks for all the info and advice guys,this makes my decision much easier. t
Thanks again
Old 08-16-2016, 12:24 PM   #10
partsstoreguy
I see a lot of people saying to use chevelle headers but i have not seen where anyone has put what year chevelle header works best.
partsstoreguy is offline   Reply With Quote
Old 08-16-2016, 04:38 PM   #11
snj8198
snj8198's Avatar
This is the set I went with. Hooker seems to be doing a much better job of offering our era specific headers. Granted there are Chevelle headers that do work well, there's not as much guess work now.
https://www.summitracing.com/parts/hok-2463-1hkr
Based off this design you'll be able to modify your search function with Summit to find headers with different size options.
Good luck.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 08-17-2016, 12:15 PM   #12
IIGW
here is the set I used. at $200 bucks for super comps, its a steal..
http://www.jegs.com/i/Hooker-Headers/520/2455/10002/-1
Old 08-24-2017, 08:48 PM   #13
novice
I just purchased these as well. I'm having issues with the drivers side. Running into interference with the motor mount and the lower control arm. Wayyy more modifying than I would like. I may just sell these and try a different brand.
novice is offline   Reply With Quote
Old 09-13-2017, 02:59 PM   #14
stevenbear72
stevenbear72's Avatar
I used some Headmen longtubes off ebay, work fine so far. I wrapped them in fiberglass.
68' Cst10 w/69 front, 5.3/4L60e swap, 12 bolt 4.11's
Project "Huckleberry"
68 GMC K1500 1/2 ton L83/6L80e
stevenbear72 is offline   Reply With Quote
Old 09-13-2017, 03:05 PM   #15
novice
I ended up using the Hookers I bought. A ball pein hammer made pretty quick work of the interference problems.
Old 09-21-2017, 12:12 PM   #16
racerop
racerop's Avatar
When replying they work or fit for your particular
application it would be nice to add year and
2wheel or 4x4(c10,c20,k10,k20). I would assume
in this thread we are all talking about 4x4 but
someone mentioned lower control arms.
racerop is offline   Reply With Quote
Old 09-21-2017, 02:29 PM   #17
novice
My mistake. My truck is a 1968 short fleet 2WD. I was just replying to the big block header inquiry.
Old 09-24-2017, 06:06 PM   #18
Old57
Im using a 73 K20 chassis under my 57 with a 454, and I used Hedman 68610 headers. They are a 3/4 length header and are for a Chevelle application. The driver side fit perfect, and the passenger side fit perfect except I had to clearace a small area on the top frame rail to clear one of the header tubes.
My 57 GMC build
Old57 is offline   Reply With Quote
