Old 02-02-2016, 11:45 AM   #1
greywurm
Was this bar standard?
Stupid Question Time!
I like to look at pictures of other trucks just to compare and see what other guys are doing to theirs.
One thing that I keep noticing if there is a picture of it is this bar on the rear diff to the frame... What is it and was it standard or an optional add on?
Sorry for the dumb question... I am still learning certain aspects of vehicles.
71 Long bed C10 w/68 front clip, 350 SBC+HEI, TH350
06 Yukon XL Denali - Stock
greywurm is offline   Reply With Quote
Old 02-02-2016, 12:14 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Was this bar standard?
That's the panhard bar. Standard equipment on all coil spring/trailing arm trucks. It locates and keeps the rear end in the center of the truck.
Remove that bar and the rear end will wiggle left to right.
Also, if you lower a truck (I think 5" and more) it needs to be replace with an adjustable one so that the rear can be re-centered under the truck.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-02-2016, 12:20 PM   #3
greywurm
Got ya. Thanks.
If the bushings are worn out, what kind of issues would that cause?
Old 02-02-2016, 12:20 PM   #4
'68 Newtricks
'68 Newtricks's Avatar
Kinda holds the axle in the center, mandatory
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 02-02-2016, 12:22 PM   #5
'68 Newtricks
Originally Posted by greywurm View Post
Got ya. Thanks.
It will let the axle move some side to side. Might just act funny at times, like a tire with low pressure
'68 C10 SWB
'85 K30 Blazer
Old 02-02-2016, 12:26 PM   #6
greywurm
Ok. I'll add it to my list of stuff to replace. I do have some weird handling issues but I think its up front... either the power steering box (leaky) or pitman arm/idler arm. Already replaced all tie rod ends.
Thanks guys.
Old 02-02-2016, 12:46 PM   #7
67ChevyRedneck
How far can you move the steering wheel before "something happens." The gear box tends to get worn out on these trucks, especially the non power steering ones.
Jesse James
Project "On a Dime"
Old 02-02-2016, 12:58 PM   #8
greywurm
It mostly has to do with trying to keep the truck straight on the highway. I have to constantly correct the steering as it likes to wander a bit once you get up around 60+.
My thoughts were that maybe the linkage parts were worn and give way while driving, the gears in the box are worn, or the power steering leak causes inconsistent pressure in the system.
There is also a decent amount of bump steering, but I think the truck doesnt handle bumps well so I'd try to tackle that first. I might have picked too stiff of a shock when I replaced them a year ago. She is pretty bouncy.
Old 02-02-2016, 02:21 PM   #9
frenchy51
frenchy51's Avatar
If I were you I'd go to a good alignment shop and have them check all front end components for wear (check brakes while you're at it) then have them do an alignment. Not enough caster will make your truck wander but warn components will do the same....
frenchy51 is offline   Reply With Quote
Old 02-02-2016, 04:28 PM   #10
greywurm
Good suggestion, and it was something I have considered - the caster.
But after I did the tie rod ends, I took it in for an alignment. Looks like I actually did a pretty good job of getting the new ends on where the old ones were because they didnt have to adjust much of anything to get it back to spec. But I have been reading a lot of guys on here have a lot of issues getting their alignment done correctly at modern shops because they just arent set up for our aged trucks any more. Idk.
I had asked them to look it over, and they just blamed the steering box because "its old." If I get really stuck on figuring it out, then I have a mom and pop shop here that I've used for things I dont trust myself to do and will take it to them. He actually has worked on pre 2000 vehicles unlike some of the guys at the local chain shops.
Old 02-02-2016, 04:35 PM   #11
snipescastle2
snipescastle2's Avatar
Talking Re: Was this bar standard?
Might "Dog Track" a little, or like the "tail wagging the dog" probably the easiest way of putting it, not to mention, if the bushings are gone, it might be clanking back and forth on acceleration/deceleration.
Ben
snipescastle2 is offline   Reply With Quote
Old 02-02-2016, 04:47 PM   #12
brad_man_72
the boat guy
brad_man_72's Avatar
Replace the panhard bar bushings, it will definetly cause a handling issue. And find a different mechanic.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-02-2016, 05:07 PM   #13
67 chevelle
67 chevelle's Avatar
agree can cause "bump steer" , couple that with a "toe out" alignment , and truck will go everywhere you dont want it to
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
