Old 02-02-2016, 01:03 PM   #1
drewbert41
drewbert41's Avatar
Bolt size info needed
Can someone please tell me the size of the bolt in the bottom left corner of the image?
drewbert41 is offline   Reply With Quote
Old 02-02-2016, 02:12 PM   #2
frenchy51
frenchy51's Avatar
Re: Bolt size info needed
If you're asking what wrench to use to remove it-it takes an allen wrench-not sure size-use one that fits it snug. They make them that can be used on a ratchet wrench like a socket....Hard to tell fro the poicture but it looks like it might be "buggered" up? If so try a vise grip to remove. You'll ruin the bolt but you'll get it out...(hopefully)
frenchy51 is offline   Reply With Quote
Old 02-02-2016, 02:31 PM   #3
IIGW
3/8-16 1 to 1.5 in length, probably 3/8 allen head
IIGW is offline   Reply With Quote
Old 02-02-2016, 05:01 PM   #4
drewbert41
drewbert41's Avatar
That is not my engine. I just lost that bolt when I took my alternator off to install headers. Looking for what size bolt to buy to replace it with.
aw hell basically I need every nut and bolt in the picture as mine are all rusted and I lost track of what is what.
Old 02-02-2016, 05:41 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Just be sure and buy at least Grade 5 bolts for the engine components.
LockDoc
Leon
Old 02-02-2016, 08:19 PM   #6
Grumpy old man
Grumpy old man's Avatar
5/16 x 1" with 9/16th hex head
Grumpy old man is offline   Reply With Quote
Old 02-03-2016, 07:19 AM   #7
Redline novdog
Redline novdog's Avatar
x2
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 02-03-2016, 08:28 PM   #8
Gromit
The board took care of you already here but if you need any other bolt sizes, this site has been a help to me:
http://www.torkspec.com/torkspecme.a...-5.7L-350ci-V8
Or if you have a different engine you just go to the main site, select "Engine Torque Specifications" and then choose your engine and it will give you all or most of the bolts - even for the 396, 454, 402; etc.
It also has most of them for every other system on the car or truck; chassis, suspension, etc.
I've checked some of these against the GM Performance figures and it seems to be generally correct; though I would recommend having another source for critical torques.
I'll try to attach a pdf of the list for the 5.7 liter 350 small block below:
I feel your pain regarding previous owners and stuff missing.. one bolt at a time it seems to take forever!
Gromit is offline   Reply With Quote
