Old 02-02-2016, 04:26 PM   #1
akqj9
1964 C10 steering bearing
My C10 steering wheel grinds when I turn it like the bearing is bad. I also had to unhook my horn because when I turn the wheel full lock it would honk. There is no slop in the wheel, just tight.
How much trouble is it to replace the bearing (or bearings?) and where should I get the parts?
thanks
akqj9 is offline   Reply With Quote
Old 02-02-2016, 04:29 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 1964 C10 steering bearing
If just the upper bearing that needs replacing, it's easy. Just pull the steering wheel off and you can get to it. If the lower one needs it, you'll need to pull the whole column out and disassemble it completely.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
