Old 02-02-2016, 07:21 PM   #1
jhngardner367
jhngardner367's Avatar
'O2 S-10 engine siezed.
I bought this truck,sight unseen,for $200. (2200 Vin 5 engine)
They told me the engine was siezed,and it has a couple of minor issues,that I'm not too worried about.
My question,is this,Should I get the rebuild kit($400),or another engine?
I'm on a budget,so I need to save as much as possible.
What are the odds it's a head,or crankshaft ?
I'm not that familiar with these trucks,but I liked the price.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
Old 03-09-2016, 12:43 AM   #2
northern
northern's Avatar
Re: 'O2 S-10 engine siezed.
Another engine, find a local salvage yard. There are good runners out there.
Brad
64 C-10, 406 sbc
th350, ford 9" floater
northern is offline   Reply With Quote
Old 03-09-2016, 04:51 PM   #3
jhngardner367
None have any S10's,but I got a head from a '99 Cavalier,with 34k on it,for $80.
Old 06-16-2016, 03:25 AM   #4
jhngardner367
Been a while,since my post.
Got the engine freed up,and turning over.
Checked the rod,and main bearings,and found no damage,or bad wear.
Timing chain/tensioner is within specs .
Pulled the head ,and found cyls 1 & 2 have crescent shaped holes,near the valves,causing the coolant leak.
PO stated they used E-85,to save $$.
It's supposed to be a "Flex-fuel"engine,but it looks like detonation damage,but the piston tops are normal.
Piston clearance is right on the money,and no sign of scoring on the walls.
QUESTION:
Is this engine noted for head problems?
