![]() Join Date: Jan 2012
Air Management Question
Anyone running the azperformance air management kit. Seems like a pretty good starter kit. I'm running bags on a 72 stepside. i have all the bags just need a management system.
Kit Includes: 1 - Viair 380 Compressor 1 - 200 PSI Viair Pressure Switch 1 - 40A Relay 1 - 5 Gallon Black Steel Tank Optional 4 Gallon Aluminum Tank (+$25) 1 - Gauge panel 2 - Dual Needle Gauge 1 - Paddle Panel 4 - Paddle Valves 60' - 1/4" Hose 1 - 1/4 HOSE 1/4 Mnpt 90* 1 - 1/4 MNPT Plug 1 - 1/4 NPT DRAIN 7 - 1/4" Barb T 4 - 1/4" Barb to 1/8"F Npt 1 - 1/2 Mnpt 1/2 Fnpt 90* 2 - 1/2 Mnpt 1/4 Fnpt 1 - 1/2' MNPT PLUG 1 - 1/2 Mnpt 1/8 Fnpt Plumbing Diagram Price: $595.00 Any input appreciated |
Re: Air Management Question
I bought the Accuair stage 2 setup from them. I already had 2 Viair 480c compressors but needed everything else. Call & talk to Travis over there and he will walk you through the system and help you with whatever changes or upgrades you want. I would upgrade to an aluminum tank to prevent rusting issues, but the rest seems good. I have all 3/8 lines & fittings but I'm sure the 1/4" will do the job, just won't be super fast or anything.
I've bought my airbag setup, Boyd's aluminum gas tank & Dakota Digital gauges from Travis, he really knows his stuff. |
a single Viair 380 on a 5 gallon tank is going to struggle to keep up. i have dual 380's on dual 3 gallon tanks (6 gallon) and it works the 380's pretty hard.
#4 | |
Old member
![]() Quote:
Do they have the 3/8" line system with e level? All I have seen is 1/4" valves. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I bought the newer version manifold with the 3/8" NPT threaded ports. Right now I have the brass push in fittings going to 3/8" DOT tubing, but will eventually go with aluminum hardlines.
Also, I agree with Willie Makeit that the single 380 compressor is gonna work pretty hard to fill a 5gal tank. But it can be done otherwise Travis would not sell it that way. Optimally you'd want to add a 2nd compressor or maybe go with a bigger compressor with an aluminum tank IMO |
#7 | |
Just give me a call or shoot me a PM. The guys are right, although the 380C will work on a 5 gallon tank, the dual setups work better, if budget allows. The max I would go on a single compressor is 5 gallons. We can always add in a dual compressor, and is cheaper when doing it off the get go (can do a dual pack), than adding later down the road. - Travis 480-420-8175 |
Thank you guys for the responses. I'll give them a call today
Stalker Nate
Like what's been mentioned go dual comps in the beginning and down the road when money permits you can change out the PTC fittings to something better. Personally I only run hydraulic line with brass fittings on air systems as it'll last forever, but it's not cheap of course.
1957 GMC SWB stepper modified summer time driver 1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project 1965 Chevy P10 Ice Cream Truck project Instagram - TheDonutDiner FaceBook - @UscreamIscream |
