Old 02-02-2016, 09:05 PM   #1
69andHalf
Hate to ask but need to identify my rear axle
I'm looking to purchase some new axles to convert my 6 lug to a 5. My truck is a bit of a Frankenstein as the previous owner used several donner trucks. This is my problem. The rolling chassis is a 69 and the cab etc is a 70. The numbers I can make out are:
NF38.....
And I can't find that combo on this website.
http://www.348-409.com/differential.html
Help!
69andHalf is offline   Reply With Quote
Old 02-02-2016, 09:13 PM   #2
69andHalf
Re: Hate to ask but need to identify my rear axle
Found somebody else looking for a stamp code:
nf3896838
Pretty sure that's mine also. Says it's from a 70. Can anyone confirm that?
Old 02-03-2016, 02:52 AM   #3
Sklptrljay
Sklptrljay's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=578793
Try this link, it has all the charts. I don't see your code and it doesn't sound like a 67-72 code. Are you looking on the top of the passenger side tube?
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 02-03-2016, 09:28 AM   #4
Jrainman
Jrainman's Avatar
axle code you are looking for is on passenger side of axle ,I have found stampings on these rears vary a little , they are in line so to speak with your stock shock mount , sometimes behind the shock mount sometimes 2-3 inches closer to the diff housing ,but in that general area
Jrainman is offline   Reply With Quote
Old 02-03-2016, 09:37 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Posts #8 & #19 in the above thread show a couple of the code locations.
LockDoc
Leon
Old 02-03-2016, 11:22 AM   #6
69andHalf
LockDoc
Thank you so much! I located the code in question TDA 0615 2
Looks like it indeed is a 70' so I think
Old 02-03-2016, 05:08 PM   #7
El Dorado Jim
love this forum, everybody is so helpful
El Dorado Jim is offline   Reply With Quote
Old 02-03-2016, 05:54 PM   #8
CC69Rat
CC69Rat's Avatar
Being a 70 axle it could be a different length. 67-late 69 and early build 70 trucks had a narrow axle housing. Late 70 on up had a wider housing. Measure between the inside edges of the brake backing plates. The early housing will be 55.5" long. The later housing is 57"
If you're ordering axles and have 67-70 55.5" housing you want the 30.5" long 5 lug axles. If it's the 57" housing you need 31 5/16" axles.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 02-03-2016, 06:42 PM   #9
69andHalf
Thank you so much again! Y'all have been very helpful!
