Driveshaft ?'s
I've been contemplating a longbed to shortbed conversion, but have been put off by driveshaft purchase. I have a few questions: Does anyone have the length of their shortbed's driveshaft with a 3 speed saginaw trans? And does anyone know if a 88-98 driveshaft will work, as in the u-joints? I can shorten the driveshaft, i just need a cheap 1 piece to start with
Re: Driveshaft ?'s
2wd or 4wd?
EDIT: Sorry I saw you have a saginaw transmission.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
Re: Driveshaft ?'s
2wd
Posted via Mobile Device |
Re: Driveshaft ?'s
Hi There,
I'm not positive, but I believe a lot of the 88-98 driveshafts are made of aluminum. I have "lengthened" a driveshaft by 3" to use a 6" tail trans instead of a 9" in an 81 Sierra Classic. You could probably grab a one piece shaft from a late 70's early 80's auto pickup , and shorten to what you need. I believe the saginaw has a slip in yoke like the TH 350s. (but I could be wrong) |
Re: Driveshaft ?'s
Just take your long driveshaft to a driveshaft shop and have them shorten it. Then you have a cut to fit and balanced shaft. It's affordable and takes out the guess work.
"Whoever said money can't buy happiness has obviously never seen a speed shop! |
![]() Join Date: Jul 2014
Re: Driveshaft ?'s
I have the drive shaft out of my 86 swb that had the 3sd Saginaw. I'll measure it in a little bit.
'83 Silverado Step Side '85 GMC short bed. '86 Chevy Step Side Custom Deluxe LQ9/4L80 swap (SOLD) |
Re: Driveshaft ?'s
Thank you. & The reason i need a different shaft is because my truck has a 2 piece driveshaft right now
Re: Driveshaft ?'s
Sorry I didn't get to it last night, but mine measures 58 3/8" center to center of the u-joints.
