![]() Join Date: Feb 2012
Maximum Height and Width Wheel/Tire Combo without Modification?
I have a 1987 R10 2WD with a 4/6 STATIC drop in the works, and need some input...
What is the maximum height and width Wheel/Tire Combo I can run front and back without any modification or inner fender removal? Would love pictures if you can provide them! |
Diggin The SquareLife
Re: Maximum Height and Width Wheel/Tire Combo without Modification?
You can run 22"wheelsim pretty sure if you search the forum you will find the threads that have already been made bout this
![]() Join Date: Dec 2006
Not knowing what size wheels you want you should be able to run a 27.5-28" overall height on the front and 29-30" height in the rear with no modifications or rubbing. I run 20x8 & 20x10 wheels with 245/40 & 275/45 on all my trucks, and a 1-1/4" rear spacer on the back with no problems on a 4.5/6 drop. I hope this helps.
#4 | |
![]() Join Date: Apr 2013
1966 C10 Mary 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
