Old 02-03-2016, 03:28 PM   #1
Tom
driving is in my blood
Tom's Avatar
Re-drilling brake rotor bolt pattern?
Thought I'd ask in here as all the project savy peeps use this forum and its not year specific
I've read how to swap NBS rear disk brakes onto the oem axle for OBS trucks. Works great for 4wd's as they are already 6 bolt wheels like all NBS trucks. I have a 2wd, with the 5x5 bolt pattern. Can a 6x5.5 bolt pattern rotor be drilled with the 5x5 bolt pattern so I can put rear disks on my truck? Without the machining of the rotors my disk swap will only run about $400, huge saving vs aftermarket options.
Old 02-05-2016, 07:45 AM   #2
PGSigns
PGSigns's Avatar
Re: Re-drilling brake rotor bolt pattern?
If you lay it out I think you will find that a couple of the holes end up part way in other holes. Ran into this issue the first time I wanted to redrill 73 to 87 rotors to 6 lug for my 65. This is not a problem on a milling machine using an end mill to do the holes. The cost to have them drilled may impact your savings and if you need to replace a rotor the time and cost needs to be planned for. I assume that the rotors are hub centered.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-05-2016, 07:55 AM   #3
andrewmp6
Have you looked at other options like http://67-72chevytrucks.com/vboard/s...d.php?t=382633
andrewmp6 is offline   Reply With Quote
Old 02-05-2016, 03:24 PM   #4
Tom
Tom's Avatar
Yes I've spoken with him and nothing for 88-98's.
