Question, 1971 Auto turn signal
Hello,
As stated I have a 1971 Chevy C/K-10 with automatic and I want to replace the turn signal switch. I have read some of the posts on the forum but I am at the early stages and need to clarify a few things. I am including a picture of the column. It is a non-tilt non-key column. I have the wheel off and removed the signal arm and I have loosened all three Philips screws on the switch but I need to somehow get the push in hazard switch which protrudes through a side hole removed so I can pull the switch out. How do I remove the switch from the housing. I'm sure that once I get past this point I'll have other questions. Thank you for your patience. |
#2 | |
![]() Quote:
#3 | |
Re: Question, 1971 Auto turn signal
18 year old girl who loves old trucks •Previous Projects• 1971 c10 longbed 350/350 1977 Silverado longbed 350/350 1978 K10 shortbed 350/t400 lifted 6 inches on 33s "LONGBED LIVES MATTER" |
#4 | |
![]() http://www.classicparts.com/mobile/1.../#.VrN2OcuIbqA |
Thank you for your help, so I have everything loose and I see it should all come apart fairly easy. Now here is a simple question, I need to pull off the shifter handle and it appears to be a pin holding it in place but its hard to see under the pin. Is it just a push pin that can be driven out? thanks
Have you looked at the factory service and overhaul manuals?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
No, I just bought the truck and I am asking the question here from knowledgeable members before resorting to buying manuals.
#8 | |
Thank you, I thought so but even with my glasses on I couldn't see the under side of the pin hole.
