Old 02-03-2016, 07:27 PM   #1
tucker69
tucker69's Avatar
Lsx intake manifold options
Does anyone have a solution for an aftermarket intake manifold for the truck 6.0 ls LQ4 engine WITH CATHEDRAL PORT HEADS ... This is a cable driven throttlebody.. My research tells me that aftermarket intakes have several issues when used on a truck motor..
1) truck injectors are shorter/taller and will not work with aftermarket intakes
2) truck serpentine access. System will interfer with throttlebody because aftermarket intakes are lower than trucks
3) aftermarket intakes are for larger mm throttlebodys and hence need for bigger t/b.
So in a nut shell i have to buy: Car injectors, larger t/b and car access. Setup to run most aftermarket intakes on my truck ls engine
i did find that "fast" and "msd" both make a truck intake with only the need for larger t/b, however im not real excited about the looks of there $1000 intakes.
So my question for all you "ls" swappers is have any of ya'll solved this problem and if so, how?
Or am i wrong in my research and if so please correct me with some much needed advise..
Thanks guys, casey
tucker69 is offline   Reply With Quote
Old 02-03-2016, 08:57 PM   #2
homemade87
Re: Lsx intake manifold options
Dont waste your money on aftermarket intake . If engine is stock with a cam the tbss/truck intake is hard to beat . Its the best rated gm intake . Great for low end torque . Unless you have the mods for a aftermarket intake you will not see any benefit over the tbss intake . The low end to midrange is where the tbss intake shines .
If you are only going for the look , thats another story .
Also you can not run a car intake on a truck motor with out spending a few more hundred on changes . Go with the truck intake if it is a must .
Heres some good info on the ls intakes . http://www.hotrod.com/features/1507-...ifolds-tested/
homemade87 is offline   Reply With Quote
Old 02-03-2016, 09:15 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
If you NEED to go with an aftermarket intake (ie the rest of the setup makes the intake a choke point), then you're already well past NEEDING different injectors. At that point, your better off switching to EV1 or EV6 injectors for the future. However, as had been mentioned, on a stock motor, these things will actually create more problems than solutions.
IIRC the LSRxT is/was made in a cathedral port setup.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-03-2016, 09:45 PM   #4
FarmerSid
FarmerSid's Avatar
Everything you have researched tucker is correct. I really depends on what you want out of your engine and the look. Fitement might determine what you go with too
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 02-03-2016, 10:35 PM   #5
65standard
65standard's Avatar
What about the Dorman TBSS intake. It's cheap and looks more like an LS car intake, only taller, more like the dodge intake on the 6.1 Hemi.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 02-08-2016, 04:33 PM   #6
tucker69
tucker69's Avatar
Thanks buddy, that was aggod article, helped me make my choice.. Casey
Old 02-08-2016, 04:37 PM   #7
tucker69
tucker69's Avatar
Thanks guys, my engine is not stock and I did not any of the stock truck manifolds due to appearance. I ordered the "Fast LSXRT" truck manifold last week. It will work with my stock components for now and afford me the ability to upgrade as needed.. Again thanks for everyones advise and opinions....Casey
