02-03-2016, 07:41 PM | #1 |
Does 55-59 have lead seams?
On the piller post between windshield and front of door where the drip rail tappers off and ends is that a leaded seam? On my truck it's cracked straight across on both sides. I can take my finger and peal up what looks like sheet metal?
02-03-2016, 10:24 PM | #2 |
Re: Does 55-59 have lead seams?
Yes,They are normally leaded. just heat area until lead runs out,wirebrush while hot,grind area, then weld solid and finish as necessary
02-03-2016, 10:26 PM | #3 |
Hollister Road Co.
yes that's the roof to A pillar joint. You can melt it out and use All Metal in its place. Cracking and peeling are common.
02-03-2016, 11:18 PM | #4 | ||
Thanks guys! |
