Old 02-03-2016, 08:25 PM   #1
Frankie P.
Trailing arm bushings 71 SWB
So I've used the method of removing old crusty bushings out of my trail arms. My dilemma is, once I insert the new energy suspension poly bushing in, the second piece (smaller poly ring) doesn't want to stay put. Is it necessary to use the whole kit or can I just insert the medal sleeve in the larger bushing and install? It appears that the bushing is tapered and the medal insert expands it and keeps it in tight.
Frankie P. is offline   Reply With Quote
Old 02-05-2016, 07:30 AM   #2
PGSigns
PGSigns's Avatar
Re: Trailing arm bushings 71 SWB
Need to use it all. It get sandwitched between the mount to hold it all tight. A little grease will hold it where it needs to go as you put it back on the truck.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-05-2016, 07:12 PM   #3
69gmcc10
69gmcc10's Avatar
Before bolting the arms up I put the energy suspension bushings in the freezer for an hour then I greased them up and they slid right into place, I pushed the ring on the other side and everything stayed right where it was supposed to until I bolted in place.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
