Old 02-03-2016, 11:26 PM   #1
the1066
Exclamation Blowing fuses
My 1966 pickup has been dealing with a fuse issue lately. The inline fuse from the alternator (new part, old one died) to the battery(also new). I trouble shooted everything, and replaced the voltage regulator (was also new). It also blew a fuse w/out the alternator/regulator hooked up... from a bad ignition switch connection. Now the battery is overcharged to 17-18 volts, and not blowing the fuse.
the1066 is offline   Reply With Quote
Old 02-04-2016, 12:44 AM   #2
TJ's Chevy
TJ's Chevy's Avatar
Re: Blowing fuses
Sometimes these new regulators can be faulty. I've found it best to convert to a one wire. I would check though and see if you have any shorts or major draws causing the high charging.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 02-11-2016, 08:31 PM   #3
the1066
Re: Blowing fuses
The regulator was gone, but the electronic ignition also went out, as well as having a few bad connections.
Old 02-11-2016, 11:05 PM   #4
WOLFMANmike
WOLFMANmike's Avatar
Re: Blowing fuses
i second going to a GM 1 Wire this really is the best charging upgrade .. plus on another positive note . a 1 wire really cleans up a engine bay nice to because you dont need all those extra wires going to the regulator so you can just get rid of them
WOLFMANmike is offline   Reply With Quote
Old 02-13-2016, 12:50 PM   #5
65 C20
Re: Blowing fuses
You may get a better response if you go over to the electrical forum.
65 C20 is offline   Reply With Quote
1966 c10
