Old 09-21-2003, 11:23 PM   #1
Orence1
Orence1's Avatar
Need help with vibration
Just got the 72 Cheyenne LWB on the road. New BB with a built TH-350. I am getting a nasty vibration/shimmy that I did not have with the old small block set-up. Slightly noticeable at 35mph but as I get up to 60 it gets real obvious. My first thought was a bad tire. Had the fronts checked yesterday and they were OK. Backs are brand new. It feels like a tire going bad. I have had that happen on other cars I have owned. I am wondering what else it could be if it is not the tires. Any suggestions appreciated. Thanks in advance.
Larry
Orence1 is offline   Reply With Quote
Old 09-21-2003, 11:35 PM   #2
mcmlxix
Collector of Projects
mcmlxix's Avatar
Any driveshaft mods?
Center Support Bearing?
U-Joints New/ or realy old?
Were new rear tires High Speed balance?
* Did the weights fall off?
... thats all I can think of for now ...
Rich
1972 K5 Blazer CST Click HERE
Old 09-21-2003, 11:36 PM   #3
gashog
Active Member
gashog's Avatar
I've had driveshafts and u- joints cause that type of viberation, also check center carrier bearing if still using a one piece driveshaft. Good luck
69 Custom/10 454 Turbo 400 and 70 Custom/20 350 Turbo 350, 73 cheyanne C/10 also 69 camaro Z/28 and 85 Iroc Z
gashog is offline   Reply With Quote
Old 09-22-2003, 12:16 AM   #4
Scrub
Collector of rusty Items
Scrub's Avatar
Does braking have any noticable affect? You may have a bad brake drum. If they get hot and you park the rig with the p-brake on, they can get warped and oblong. It will drive you nuts. Try jacking up one rear wheel at a time to see what happens on each side.
Good Luck
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 09-22-2003, 01:03 AM   #5
Richard
If you pulled the driveshaft make sure the U-Joints are in phase.
Richard
Old 09-22-2003, 01:50 AM   #6
Mechanic
Check your brand new rear tires and lug nut torque. My "brand new" rear tires almost came off on the way home from vacation a week or so ago. Good luck.
Shop Labor $75, if you watch $100, if you help $125, Wisecracks-$25,
Boxjobs-don't even think about it. Yes,Cash.
Mechanic is offline   Reply With Quote
Old 09-22-2003, 04:29 AM   #7
beautimus
beautimus's Avatar
a couple of things come to mind.
1. did you use an internal balance flexplate?
(if you used a small block one it is probably not right.)
2. could be a worn a-arm bushing in the front end.
3. could be a bad tire.
4. it could be a warped rim.
5. uh, thats all i can think of to check. lol
hope that helps,
tony
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 09-22-2003, 11:49 AM   #8
Professor
You don't say what your new engine is. Is your new big block an externally balanced engine? If so, did you use the harmonic balancer and flexplate off an internally balanced engine?
Professor is offline   Reply With Quote
Old 09-22-2003, 12:02 PM   #9
oldsub86
Who did the transmission? I chased a vibration in my 86 Suburban and changed a whole lot of stuff including tires, drive shaft, universal joints, rear end parts, and engine and transmission mounts, on the advice of pro mechanics - did not help at all really until I had the transmission rebuilt.
If it was not there before, check the new parts you have put in first - your new engine and new transmission would be the primary suspects.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 09-22-2003, 02:24 PM   #10
oldiron
Designated Grumpy Old Man
oldiron's Avatar
Is the vibration coming thru the steering wheel or the seat? Did you remove the idler arm when installing the engine if left loose it also will cause a vibration.
Securely (sp?) jack up the rear end and put the transmission into drive and run upto 35 mph and see if you get the vibration. If you do the check out the drive train and rear wheels. If not you might have a problem in the front end.
oldiron is offline   Reply With Quote
Old 09-23-2003, 10:24 PM   #11
Orence1
Orence1's Avatar
Put the rear wheels up on jackstands tonight, ran it up to 2500 RPM which has really caused vibration and there was nothing. I am assuming that it is not the driveshaft and I need to take a harder look at tires and suspension. Thanks to all of you who shot off some excellent suggestions.
Larry
