Old 02-04-2016, 05:39 PM   #1
karlbenz
Wheel placement help needed
Setting my cab. Not sure about wheel center. Does this look bout right
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
Old 02-04-2016, 08:21 PM   #2
PGSigns
PGSigns's Avatar
Re: Wheel placement help needed
Looks pretty close. Wheel may be turned a little left in that pic.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-04-2016, 09:48 PM   #3
karlbenz
what do you go by to level the cab from front to back? this is a 84 k10 chassis
1965 Chevy C60
Old 02-05-2016, 07:24 AM   #4
PGSigns
PGSigns's Avatar
I would level the frame on stands then level the cab. Leveling both front to back and side to side. Then once you have them both level you can center it. Them place the mounts.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 02-05-2016, 07:58 AM   #5
karlbenz
Where on the cab do you actually place the level?
1965 Chevy C60
Old 02-05-2016, 01:17 PM   #6
PGSigns
PGSigns's Avatar
I would use the bottom of the rockers fro front to back and the rear cab brace for side to side. The longer the level the better.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
