05 Z71 transfer case clunk
Well I recently purchased a 05 Chevy Silverado 4x4 and i am getting ready to service the transfer case and axles on it but on the transfer case when you are shifting from high 4wd to low 4wd it makes a clunk that is fairly loud it doesn't do it any other time just when shifting from high to Low and Low to High. 4wd functions perfectly in both its just fairly loud when switching I'd like to know if it's something I should be concerned about or not the truck is pretty much stock and I plan on using it off road quite often mostly at the sand dunes and in the snow it looks to be the original fluid in the transfer case it's fairly dark compaired to the bright blue that the Autotrak ll fluid is so is it possibly that it's just gummed up from not being used very often and the fluid being old
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. ![]() 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
| Bookmarks |
