Old 02-04-2016, 10:10 PM   #1
65chev
What is this
Hello
What is the round plastic canister? How or what does it hook up to?
Thanks, Mike
65chev is offline   Reply With Quote
Old 02-04-2016, 10:24 PM   #2
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb Re: What is this
It's a vacuum reservoir. It store's vacuum so your A/C and cruise control will remain working when there is a larger load or vacuum demand on the engine.
There should be a small check valve placed in the hose just b4 it if you are gonna reconnect it.
It just hooks up to any vacuum connection on the intake manifold.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 02-04-2016, 11:41 PM   #3
65chev
Re: What is this
Ok. The cruise works, so it must be for a/c. So a vaccum hose comes from the carb to the top. How does it get to the a/c controls? Thanks. mike
Old 03-05-2016, 12:42 PM   #4
mwooten92
mwooten92's Avatar
Re: What is this
subscribed.. I'd like to know aswell..
85 C-10 ShortBoxChevy!
Build Thread of my 85' C-10
http://67-72chevytrucks.com/vboard/s...d.php?t=367919
mwooten92 is offline   Reply With Quote
Old 03-05-2016, 04:26 PM   #5
ironroad9c1
Master Hater
Re: What is this
LOL funny I seen two holes in my truck this morning right where that is wondered what had been there.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42
"This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors
ironroad9c1 is offline   Reply With Quote
Old 03-09-2016, 07:45 PM   #6
87 STEPPER
87 STEPPER's Avatar
What you need to do is get a check Vlv and some vac hose cut a 1" piece of hose place it on the can nipple then place the ck vlv on the hose then hook Engine Vac to top of ck vlv be sure it's in the right ordination and then run a hose from the ck vlv nipple to your A/C Control head and anything else that may require it.
Here is a typical Vacuum check valve. you don't have to get one with two take offs there are many different types.
Name:  Vaccume Ck Vlv.jpg
Hope this help's.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
Old 03-12-2016, 10:10 AM   #7
plumbers crack
plumbers crack's Avatar
Re: What is this
I'd guess that your truck was or still is a big block. It's a vac reservoir, big blocks don't make good vac at times and need the reservoir to keep up good vac.
1990 GMC R35 CC dually, VE cummins, 47RH
2005 Silverado ecsb, 5.3, 2/4 drop, daily work wagon
2000 Yukon xl, 5.3 all stock, wife's truck
2007 Yukon Denali, 6.2 back up truck
plumbers crack is offline   Reply With Quote
