02-05-2016, 11:07 AM | #1 |
72 axles in my 70 rear end
I was given a pair of 5 lug rear axels out of a 72'. I'm wondering if I can just pull the clips in my diff and pop them in my 70'? Anyone done this?
02-05-2016, 01:29 PM | #2 |
Never Ending Projects
Re: 72 axels in my 70 rear end
Well it depends. Late '70 and on the axle shafts were 3/4" longer each side (1.5" total axle width). Early '70 and before were shorter. Since you have a '70, it could be either length depending on when it was built. You will have to measure your current shafts to see which ones you have. If the same length, then yes you could swap them. If yours are shorter, then no.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
02-05-2016, 01:36 PM | #3 |
OK thanks, guess I'll be doing dome checking.
02-05-2016, 04:40 PM | #4 |
The narrower rear end (early '70 and before) will measure 62.125" from wheel mounting surface to wheel mounting surface.
02-05-2016, 05:10 PM | #5 |
Thanks pro P that will save me pulling the diff cover!
