Old 02-05-2016, 12:06 PM   #1
SnS C10
SnS C10's Avatar
So when cutting down a long bed....
Well everyone, I have successfully cut my frame on my 64 c10 longbed down to the shortbed dimensions. Reinstalled the cab, swapped in a 1977 c10 disc front end, converted to power brakes. I would rather buy the repro bedsides to make it a shortbed, but don't want to spend that amount of cash. When cutting down the bed the required dimensions, what does everyone do with the seam that runs the length of the bed, just above the trim as I have noted in my picture of my truck? After the cut and weld, is there an interruption in that seam from the weld? Also, can someone post detailed pictures of this seam after they welded, and pictures of what the inside of the bedsides look like after welding. I tried the search function and couldn't find much on this. Thanks
SnS C10 is offline   Reply With Quote
Old 02-05-2016, 01:15 PM   #2
PGSigns
PGSigns's Avatar
Re: So when cutting down a long bed....
To go short bed you cut the bed sides twice once in front of and once behind the wheel well.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-05-2016, 01:19 PM   #3
SnS C10
SnS C10's Avatar
Pgsigns yes I already knew that. 12 by cab, and 8 at the rear. I was asking about the actual welding in relation to the seam that runs the length of the bed, and some pictures of the process
Old 02-05-2016, 01:34 PM   #4
Cape Codder
Cape Codder's Avatar
After welding you can grind that seam back in with a cutoff wheel.
Cape Codder is offline   Reply With Quote
Old 02-05-2016, 01:36 PM   #5
SnS C10
SnS C10's Avatar
Ok so basically use the width of the blade to re create the look of the seam?
