02-05-2016, 03:04 PM | #1 |
Chevy Astro seat question
Hey everyone! I found a '96 Astro seat with the console and armrests, but I'm not sure if it will fit. I've noticed that most of the guys install 2000 and up Astro seats in their rides, so does anyone know if a '96 seat will fit the same? Any info is appreciated! Thank!
02-05-2016, 04:43 PM | #2 |
Re: Chevy Astro seat question
They'll work.
Here's an example. http://67-72chevytrucks.com/vboard/s...&postcount=149 Now i have read concerns that you're not center to the OEM steering column. If that doesn't bug you or going to change out the column and how its mounted then nevermind. |
02-05-2016, 05:16 PM | #3 |
Awesome. Thanks a lot for that link!
02-06-2016, 01:05 AM | #4 |
2000 dodge durango seats work also, look the same, i used them only because of the color, i could not find Astro seats to match my interior.
02-06-2016, 12:09 PM | #5 |
1972 Chevelle bench seat bolted to late model Chevy truck risers fits perfect.
02-06-2016, 12:25 PM | #6 |
depends on what your ride is?
ad, tf or jd tractor? too wide for your tractor hint... put your truck yr and model in your signature link in my signature
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
02-06-2016, 04:59 PM | #7 |
I'll be reupholstering the interior anyway. The Durango seats look a little too modern. If you remove the headrests on the Astro seats and reupholster they can look pretty old school.
02-06-2016, 05:29 PM | #8 |
02-07-2016, 12:56 AM | #9 |
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
02-07-2016, 06:19 PM | #10 |
That does look good Softpatch. Backs tilt forward?
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 |
02-07-2016, 08:39 PM | #11 |
Hey Softpatch, I am installing that same seat in my 55 TF. How did you install this seat in you TF? What seat brackets and tracks did you use, as well as what seat belts? I am trying to cut down the stock 2nd row brackets and fab mounts for the floor. Not sure if I am happy with the fact that there are only three adjustments on the tracks with approximately 2 inches pf movement between each adjustment.
While at the salvage yard I also grabbed a 1990's bench seat brackets from a full size Chevy truck. Thought about using it but was concerned about the strength of those seat mounts with the astro van integral seat belt clip anchor. Thanks in advance for any help you can provide. |
