Aluminum valve cover service
Does anyone on here clean up valve covers for people? If not do any of you know a reputable person to send them to? They are Cal Custom finned valve covers.
#2 | ||
"I ain't nobody, dork."
Re: Aluminum valve cover service
Elbow grease and Nevr-dull.
![]() Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
Can you post a photo of them ? Interested to see the condition of aluminum?.....
71 C-20 07 Magnum RT AWD |
cast aluminum wheel cleaner
Everyone talks about how much of a pain it is. Id rather just put em on the way they are or pay someone. It is not a show truck so I don't mind either way. I stumbled across someone who had people mail them to him for a fee on another forum but I don't remember which one.
![]() Join Date: May 2010
I've done it with fine steel wool (eventually very fine) and Aluminum Jelly... and as stated above, a lot of elbow grease. Yours look like they'd clean up fairly easy.
EDIT: This procedure results in a natural raw aluminum finish. Not polished. |
Moderator
![]() Join Date: May 2007
Yep, eagle one will have those looking like new.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
Yet, no one is up for the job lol.
Moderator
Spray on spray off...it doesn't get any easier
#11 | |
PM me if interested. Last edited by Willie Makeit; 02-06-2016 at 09:21 AM. |
#12 | ||
I used to have a set of Centerline Auto-drags on a 1971 El Camino SS and used to use the Eagle 1 "etching" mag and wheel cleaner. Complete spray on hose off aluminum cleaner. Best wheel cleaner I'd ever used for non-coated aluminum wheels. So I don't see why it wouldn't work just as good on non-coated aluminum valve covers.
Gary
#13 |
![]() Join Date: Jan 2012
I would try the above mentioned solutions. Can't hurt. Good cleaning and shoot 'em with a rattle can. Wipe off or sand the fins and clearcoat.Should get you a nice set of covers
I will share,I tried sandblasting a set of M/T's for a SBC for my nephew. I could not get all the black coating off. I didn't try aircraft paint stripper (time constraints) .I powder coated them Chevy orange and sanded the fins.They were a pain is the rear. If only I knew then what I know now.
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS
#14 |
Interesting. I just wasn't wanting to buy a polisher and respirator and all that. Since I am not that picky the spray on and spray off option sounds nice.
#15 |
I would say you will like the end result. if you run into a mess give me a pm. I can front you some steel covers. Not a hoarder just playing with powder coating!!! I think you're about 1-1/2 away?
#16 |
Local machine shop ... trip through the hot tank - glass beaded - then sprayed with Seymour Alumi Blast. Will look great for years. Typically $30 around here.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
#17 |
Active Member
https://www.facebook.com/IpolishDit-...2207800900928/
This guy has done some for me - very good work - Check out the pictures - the Big Block B&M valve covers where the last set he did for me.
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree
#18 | |
#19 |
Wouldn't glass beading clean them up pretty well?
You could also wire wheel them to clean them and then shoot them with a good aluminum paint. I even paint a lot of my new bare aluminum because it doesn't look good 2-3 years later anyway... But if the hardcore wheel cleaner (not the enviro safe stuff!) will clean them up, all the better. I used to buy this stuff that was so acidic (or base, I don't actually know) that it foamed away on the wheels for a few minutes and then rinsed off clean. No idea how much aluminum it took with it each time though!
#20 |
I contacted a few local machine shops today with no luck. They said they do not do automotive.
Hitting them with the wire wheel and some aluminum paint sounds like a pretty good idea. Like I said I am not big on bling anyways. Would the scratches from the wire wheel show up through aluminum paint? Last edited by drewbert41; 02-09-2016 at 06:16 PM. |
#21 |
No automotive machine shops in your area? That is a shame. Ask around your local service garages. They should know.
Deep scratches will show through paint. Be sure to get them VERY clean first. A good spray with Brake Clean then a scrubbing with soap & water should do the trick. Then dry them completely. More time you spend before painting the better it will look and longer it will last |
| Bookmarks |
