Old 09-22-2003, 12:20 AM   #1
angelsairman
Future Owner
angelsairman's Avatar
FlowTech Headers
Got stuck with a bum set of headers that didnt fit. Im looking at a set of FlowTech headers that are supposed to fit. Im running a 71 C10 1/2 Ton 2WD TH350 with column shift. Has anyone used these before with this type of application?? Will these work with little to no modification???
Its not the end result that counts most...its the journey along the way that's most rewarding
My truck doesn't leak, it just marks it's territory
angelsairman is offline   Reply With Quote
Old 09-22-2003, 01:41 AM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
I had a set of Flow Tech's on my 72 C/20 w/ a 700R4 on the column and they fit great. The only reason I don't have them on now is I went to a big block...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 09-22-2003, 10:24 AM   #3
jtnixon
Have a set of Flowtechs, part number 11500FLT, on the same setup as yours. Works great with no problems on fitting. They have ceramic coated headers p/n 31500FLT also.
jtnixon is offline   Reply With Quote
Old 09-22-2003, 10:35 AM   #4
sactoC10
71 DELUX
sactoC10's Avatar
jtnixon,
any pics of that set-up ?
sactoC10 is offline   Reply With Quote
Old 09-22-2003, 11:05 AM   #5
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
I've got the same headers.... My truck is dropped 4 inches in the front though.... I have a bit of clearance issues.. btw... that's not rust on the headers it's dirt.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 09-22-2003, 04:34 PM   #6
greasemonkey
greasemonkey's Avatar
I have the coated ones and an SM465. They are very good headers.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 09-22-2003, 06:50 PM   #7
jtnixon
sactoC10, no pictures of the project.
2 1/2" drop w/spindles and no clearance problem here.
Old 09-22-2003, 06:51 PM   #8
COBALT
COBALT's Avatar
I took one look at the painted ones when they showed up from Summit, and sent them back. They were already all scraped up and looked like hell before I even got them out of the box.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
