Old 02-05-2016, 09:33 PM   #1
davee60
Junior Member
1966 K10 shock recommendations
Once again, I turn to this excellent forum for assistance!
I am having a heck of a time finding definitive part numbers for front and rear shocks for my 1966 K10 Suburban project. I would think that they would be the same as the K10 pickups, but all the vendors I have searched (Jegs, Summit, Brothers, Rancho, Bilstein, etc.) do not list a specific shock for the 1966 4X4's. Am I missing something, or do I just need to measure? The old ones were so rusty and trashed that they went right into the junk pile, in hindsight, a mistake on my part.
If anyone has some brand and part numbers that I could cross-reference, that would be great. Thanks!
Dave
1966 K10 Suburban
davee60 is offline   Reply With Quote
Old 02-05-2016, 11:00 PM   #2
Bad4wd
Re: 1966 K10 shock recommendations
Dave,
I was looking to buy Gabriel 61522 shocks for the front of my '66 K-10
but, I haven't got around to buy them.
Dave...
Bad4wd is offline   Reply With Quote
Old 02-05-2016, 11:45 PM   #3
jtrichard
Here you go http://www.4wheelparts.com/Suspensio...t_pn=exp132000
You might want to call them to see if its stock height or not
jtrichard is offline   Reply With Quote
Old 02-06-2016, 08:18 AM   #4
evan396
Look up jimal, he did a post on his 66 k10 shocks.
evan396 is offline   Reply With Quote
Old 02-06-2016, 07:48 PM   #5
davee60
Junior Member
Thanks Everyone for your input. The ProComp shocks at 4WheelParts look to be for an 8-10 inch lift, according to the description. The specs on the Gabriel shocks appear to be closer to the other shock specs that I have been looking at, but I'm going to get a measurement just to confirm that I'm in the ballpark. Thanks again!
Dave
1966 K10 Suburban
Old 02-07-2016, 08:46 PM   #6
maxwoof
I was able to use Monroe Gas Magnum #34944 on the fronts. I had to buy the upper stud post separately, press out the metal bushing in the top of the shock and press in the stud. Been in there for about 5 years now, seems to work OK.
The rears have an odd sized through bolt at the top, I think it is 3/4? Regardless, it is hard to find a shock with the right top bushing. I think it could be done with a series of spacers and a 1/2" through bolt. The bottom attaches to a stud similar to the front shock top, I think you would have to press out the steel bushing.
Below is link to a Monroe page - click on mounting and length sheets, it has some helpful info. The pics are from my 62 K-20.
http://www.monroe.com/en-US/catalog/Misc-Information/
maxwoof is offline   Reply With Quote
Old 02-07-2016, 09:37 PM   #7
RANDY COX
RANDY COX's Avatar
can we see some pixs of your K-10 please..
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 02-08-2016, 12:10 AM   #8
BigSix
Front can easily be found. Rear is not made with a bushing that big anymore. Nothing even close. Some weld washers and then you have a standard 1/2" hole.
BigSix is offline   Reply With Quote
Old 02-08-2016, 01:09 PM   #9
chase@ridetech
chase@ridetech's Avatar
If you could get me the Installed Height of the shocks (mounting point to mounting point with the weight of the vehicle on the suspension) I can provide part numbers. I have both adjustable and non adjustable Q Series options with a 1,000,001 warranty.
chase@ridetech is offline   Reply With Quote
Old 02-08-2016, 02:09 PM   #10
61K10
61K10's Avatar
I couldn't find any to fit my 61 either. the 3/4 holes in the rear was the problem. I bought some Monroe's and some poly bushings with a 3/4" id and turned them down to fit the shock eyes.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 02-09-2016, 10:47 PM   #11
'63GENIII
'63GENIII's Avatar
I run Rancho 9000 adjustables on mine. I think that I just took measurements from stud to stud and provided it to the sales person that I spoke with. Everyone who has said the problem with the upper rear bolt is right though. I just ran the bolt through the poly bushing with no sleeve. Probably have nearly 30,000 mi on them with no problems.
If you want the part #s for these, I can get them for you tomorrow.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 02-09-2016, 11:24 PM   #12
BigSix
I have my rear Ranchos with bolt right through poly bushing without the sleeve. But recently have purchased new bushings and will be installing weld washers so I can run 1/2" shock bolts.
Old 02-09-2016, 11:35 PM   #13
'63GENIII
'63GENIII's Avatar
Just read your sig. Thats some hardware you got in that rig! Sorry for the hijack. Back to our regularly scheduled program.....
Chris
'63 k15 long step
Old 02-10-2016, 10:49 PM   #14
BigSix
I should update the signature because I'm at single turbo now. But its a brand new Holset shipped from Holset...and it cooks.
Old 02-12-2016, 09:32 AM   #15
Jimal
Jimal's Avatar
Did someone say Jimal?
As others have mentioned, the front shocks are easy. The rear shocks were bit more of a challenge. I followed BigSix's suggestion from this thread and used Rancho RS5601s for the front and RS5143s for the rear. I had none of the hardware, so McMaster Carr and Tractor Supply became my friend.
Jimal is offline   Reply With Quote
Old 02-12-2016, 11:00 AM   #16
BigSix
Looks good. I am editing my suggestion and saying the best way to do it is using weld washers to reduce that bolt size. I just bought a new set of rancho bushings and will be installing fresh bushings and reducing bolt hole sizes with some fresh 1/2" hardware (grade 8 for street cred).
