Old 02-06-2016, 12:06 AM   #1
Dan Wales
Original A.C or Vintage Air
Hi everyone looking for a little advice/help. I'm trying to get started again and finish this 71 shortbed. Been feelin kinda bad for a couple years I think I have that straightened out now.
It was a AC truck to start. The controls are about all that is left. They do work.
The firewall is clean, controls and outlet eyeballs are about all that is left.
I know we have hundreds of folks on here with many, many rebuilds.
In your opinion would it be better to find original parts piece by piece or go with Vintage Air. Price wise I'm not sure if there would be that much difference.
Appreciate all advice.
Dan
Dan Wales is offline   Reply With Quote
Old 02-06-2016, 12:28 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Original A.C or Vintage Air
Since you are starting from scratch, I vote vintage air.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 02-06-2016, 01:04 AM   #3
Gatorman
The 72 C10 I`m working on was restored several years ago. I myself purchased it after it sat for a few years. It is a Cheyenne and was a loaded truck. It`s a factory Ac truck. The former owner cleaned up the firewall and it now has a Vintage air system. I agree, if starting from scratch why not do a Vintage AC setup. Just my $$ .02. Dale
Gatorman is offline   Reply With Quote
Old 02-06-2016, 02:27 AM   #4
F.A.A.benny
Cost will be about the same. So the question is do you care either way? If you don't care about having the factory look then go with aftermarket. But if would prefer factory, then its not that hard to get everything you need.
F.A.A.benny is offline   Reply With Quote
Old 02-06-2016, 10:24 AM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: Original A.C or Vintage Air
Factory AC/Heater box with 134-A Freon is the way to go. Look's right and is easy to do if you have the parts. I wouldn't change it out if I had all the factory stuff that for sure.
My opinion is the under hood pictures you see of these trucks and they shaved the fire wall's and added the aftermarket AC system makes them look funny like something is missing and it is!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-06-2016, 10:41 AM   #6
Hart_Rod
Hart_Rod's Avatar
Vintage Air....
Hart_Rod is offline   Reply With Quote
Old 02-06-2016, 11:16 AM   #7
GoodJobTim
So Vintage Air works just as well as factory for everyday driving?
GoodJobTim is offline   Reply With Quote
Old 02-06-2016, 12:02 PM   #8
69chevy4wheel
69chevy4wheel's Avatar
I think it does depends on the build of the truck. If most everything else is original I would keep the a/c system original. If its customized go with vintage air. With that said my truck is customized and I just finished installing a vintage air system. If you decide to go with the original system message me as I have most of the parts you may need.
69chevy4wheel is offline   Reply With Quote
Old 02-06-2016, 01:13 PM   #9
72MARIO
72MARIO's Avatar
I would say NO
Unless your bringing fresh air from outside into the cab (none of the aftermarket units offer this) I would say there not ideal for daily use. Thats from my experience specifically with the OLD AIR system personally I dont like it.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-06-2016, 01:18 PM   #10
davepl
davepl's Avatar
If you have most of the old system, make the old system work. It has the fresh air, cowl door, bi-level operation stuff that I don't think Vintage has.
If you're piecing together a factory system and don't have it, it can likely get pricey without a full donor system. Then I'd go aftermarket.
Unless this is for a stock restoration, then you have no choice, but hard to do a stock restoration on an AC truck without all the AC stuff!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-06-2016, 02:07 PM   #11
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Vintage air
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 02-06-2016, 02:49 PM   #12
F.A.A.benny
Originally Posted by 72MARIO View Post
I would say NO
That is an advantage of the factory system. It has a fresh air mode. The aftermarket kits like vintage don't have that.
Old 02-06-2016, 03:52 PM   #13
In The Ten Ring
Keep it original brother....as original as you can.
That's what I'm doing with my truck and if I was buying one, I'd pay more for one kept original.
In The Ten Ring is offline   Reply With Quote
Old 02-06-2016, 08:25 PM   #14
57larry
Vintage air & heat
57larry is offline   Reply With Quote
Old 02-06-2016, 09:40 PM   #15
RustyBucket
RustyBucket's Avatar
pm sent
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 02-07-2016, 12:54 AM   #16
Z10
Z10's Avatar
Another vote for Vintage Air. Works fine in this West Texas heat.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 02-07-2016, 08:24 AM   #17
hdff
hdff's Avatar
Original, just finished redoing mine
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 02-07-2016, 09:32 AM   #18
My '72 is an A/C truck with all parts present. I will restore that system.
My '67 is built from scratch out of parts from the ground up. I will install Vintage Air
Old 02-08-2016, 12:53 AM   #19
Z10
Z10's Avatar
Or......this?
I still can't figure out why these pics are loading sideways?
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 02-08-2016, 02:23 PM   #20
mrein3
mrein3's Avatar
I always tell people if you have more money than time go with an aftermarket system.
If you're like me and the opposite is true, go original.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 02-08-2016, 11:30 PM   #21
One thing for those who live where it gets cold to consider is how good is the Vintage Air heat? All the focus is on A/C. I have no idea how good that heat works. I know the factory heat is fantastic
Old 02-09-2016, 01:49 PM   #22
mrein3
mrein3's Avatar
Good point. My snow plow was purchased prior to my non-AC to AC mod to the truck. The old, non-AC heater was anemic at best. The current heater, a factory AC heater core setup, is TOO HOT !
I usually finish my plowing with the window rolled down.
'72 Malibu hard top
Center City, MN
Old 02-09-2016, 02:13 PM   #23
jus2qwk
jus2qwk's Avatar
Run vintage are and you can clean up the firewall and also run one of these sweet heater control panels haha
Corey Jones Designs
CoreyJonesDesigns on instagram
Ole Silver- 1967 stepside
http://www.hotrod.com/articles/1103c...chevrolet-c10/
http://67-72chevytrucks.com/vboard/s...d.php?t=598758
jus2qwk is offline   Reply With Quote
Old 02-09-2016, 02:54 PM   #24
F.A.A.benny
Anyone running a Classic Auto Air ac kit? What about Old Air Products? Or is just about everyone on this forum running VA? If so that's interesting because CAA is the same thing and alot of the chevelle/mustang guys use them.
Old 02-09-2016, 03:14 PM   #25
iGreek
iGreek's Avatar
I've seen the controller online on Dakota Digital's site, but where did you get the bezel for the controller from? Looks real nice!
1972 Chevrolet C10 LWB
iGreek is offline   Reply With Quote
