Old 02-06-2016, 05:08 PM   #1
Franklin1775
Rewiring issue with starter
Hey guys, hopefully some of you truck gurus can help me out here.
I have a 1965 C10 that has a circa 76 monte carlo 350 SBC in it. I also have a HEI distributor in it so no need for the wire from the starter to the resistor. I'm in the process of rewiring it using a EZwiring harness.
I hooked up the IGN switch today and tried to start it. The starter engages when the key is in the "run" position. Also, when in the start position the engine would fire once then not fire any more, but the starter would still spin.
The kit has two wires that go to the ignition switch that I'm confused about. It has a IGN COIL wire that I hooked up to the SOL terminal of the ignition switch. Then it has a IGN SWITCH IGN wire that I have no idea about.
Franklin1775 is offline   Reply With Quote
Old 02-06-2016, 05:41 PM   #2
PGSigns
PGSigns's Avatar
Re: Rewiring issue with starter
It is wired wrong. The Sol terminal on the switch goes tot he starter and the IGN COIL wire goes to the IGN terminal on the switch that is hot when the switch is on. The Ign coil wire should be hooked to the HEI'
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-06-2016, 09:20 PM   #3
Franklin1775
That did it, starts up just fine now. Thank you so much!
Old 02-06-2016, 09:22 PM   #4
PGSigns
PGSigns's Avatar
Your welcome.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
