WTB: 68 c10 - 12 bolt backing plates
Hey, looking for the backing plates for a 68 c10 with a 12 bolt.
Thanks!
68 SWB 5.3 turbo build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578220 |
Re: WTB: 68 c10 - 12 bolt backing plates
It would be nice to find the whole setup minus the drums, because I'm starting fresh with only new drums, shoes and the adjuster kits. I'm sure there's some hard parts you can't get anymore so it'd be nice to get those all at once.
![]() Join Date: Apr 2013
I have some rear backing plates but don't know if they came off of a 12 bolt rear axle or not. I got them with a bunch of parts I bought recently. If you think you can identify them I can get some photos for you. Thanks, Jay
Sure can. I think even the danas would share the same housing and brakes. Can I see a picture of them?
Sounds good, thanks.
I'm just glad to be here!
10 bolt truck axles thru 1987 use the same backing plates for the 2" wide drum brakes. those might be easier to find...
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
I've rebuilt my drums completely, including wheel cylinders, rubber plugs, etc and resurfacing the shoe pads. My plan is to run them for rearend break-in and when switching gear oil, Im coverting to disc. Idk what your timeline is but I can send you the entire assemblies when I take them off. They are coated with alkyd primer on the inside and topcoated with Hammered on the outside.
1968 LWB C20 / AC / Wood Bed |
#9 | |
I think if I remove the brake shoes the backing plates will fit in a 'ship anything that fits in this box' from the USPS for 13 - 15 dollars. If you want the brake shoes and all shipping will, of course, be higher. Would like to get $20 each for plates. Jay |
#10 | |
Jay, I just shipped a set of 2 3/4" plates with shoes, I had to remove on set of shoes to get them to fit in a Large flat rate USPS box for $17.90, the 2" set may fit with both sets of shoes...That's a good price, $40 plus shipping is not bad.
#11 | |
![]() Jay |
Jay, I'll take them. I've got replacement shoes, so it's no problem to remove them. The most important part to me is the backing plates and all the hardware, I've got everything else to rebuild them. Can you PM me your paypal?
#13 |
