Old 02-07-2016, 09:32 PM   #1
nascarmikeb
fuel tank issues
This thread may be posted on this site, but I can't locate it. I have an '87 GMC SWB. Of course it has dual tanks w/ electric fuel pumps. I am put in a carbureted engine, w/ mechanical fuel pump. Should I remove the electric pump? If so, what different parts, if any will I need where the pickup line goes into the tank?
Or, will the mechanical pump pull the fuel through the old electric pump?
Mike
nascarmikeb is offline   Reply With Quote
Old 02-08-2016, 08:49 AM   #2
RodsGreen10
RodsGreen10's Avatar
Re: fuel tank issues
Mike
Why are you going mechanical pump? Why remove the intank pump when you can use the Intank fuel pump for a carb. Just need Some fittings and a bypass regulator.
RodsGreen10 is offline   Reply With Quote
Old 02-08-2016, 11:02 AM   #3
nascarmikeb
Thanks for the reply..
I don't have to remove the pump, just figured I needed to.
Can you point me in the direction of the parts that I will need? I will search for a bypass regulator online, but if there are some specific one that work well, I'm open to suggestions.
Mike
Old 02-08-2016, 11:14 AM   #4
nascarmikeb
This looks like what I need
I'm running a holley 650
Old 02-08-2016, 11:32 AM   #5
RodsGreen10
As long as it is a bypass regulator. Yes. The return line needs to be as big as the feed line. Example -8 an feed -8 an return. But for that carb size -6 an will be fine.
Old 02-08-2016, 11:32 AM   #6
RodsGreen10
Do you use both tanks or just 1?
Old 02-08-2016, 12:47 PM   #7
RodsGreen10
http://m.summitracing.com/parts/rus-644123
http://m.summitracing.com/parts/rus-644113
The above goes on the hardline coming off of pump sender.
Old 02-08-2016, 12:49 PM   #8
RodsGreen10
http://m.summitracing.com/parts/sum-220107b
Use this if using both tanks.
This is uncharted waters for me on this y cause I don't have the dual tanks. But with this run both feed line into it and one up to the fuel log.
Old 02-08-2016, 01:08 PM   #9
RodsGreen10
you also will need new fuel line. What I used on mine was black braided fuel line. I used -8an but my motor isn't stock by any means. For what you have do -6an.
Old 02-08-2016, 01:09 PM   #10
RodsGreen10
And a new inline fuel filter.
Old 02-08-2016, 01:15 PM   #11
RodsGreen10
Example of tank with quick connect and some 45 an fittings
Old 02-08-2016, 01:17 PM   #12
RodsGreen10
And a close up. Now the hardline fittings I post above I ended up using them on my setup. The ones I posted above and that is what I have now are better than what is in the pic below.
Old 02-08-2016, 04:28 PM   #13
nascarmikeb
Got it that is great info
Ill start planning it now.
Only my driver side is functioning, I'd love to get both tanks going.
Old 02-08-2016, 04:35 PM   #14
RodsGreen10
Even better for me giving advice lol. Scratch the Y then.
Old 02-08-2016, 04:36 PM   #15
RodsGreen10
Get those fittings fuel line fuel filter and a fuel log.
Old 02-08-2016, 04:36 PM   #16
RodsGreen10
You want to mount the bypass regulator up as close and level to the carb as you can.
Old 02-08-2016, 04:38 PM   #17
RodsGreen10
I bootlegged this off of the Internet. But this is ideal for mounting cause this isn't a bypass reg.
Old 02-08-2016, 04:40 PM   #18
RodsGreen10
Another example. This is not a bypass regulator but example of mounting.
Old 02-08-2016, 04:42 PM   #19
RodsGreen10
This is what I have ordered for my carb to EFI now back to carb again after EFI BS. I run fuel logs so IMO this is the best of the best setup for a bypass carb system with intank pump.
Old 02-08-2016, 04:43 PM   #20
RodsGreen10
But no matter what you get or do the key is the bypass regulator and having the return line the same size as the feed line. If you do t have the return line the same size as the feed line you get a pressure drop.
Old 02-08-2016, 04:46 PM   #21
RodsGreen10
It looks like a lot of stuff but it's just plug and play really. And some money lol.
Old 02-08-2016, 04:56 PM   #22
RodsGreen10
Idk know your budget or how deep you want to get into it. But it is going to cost more that going mechanical pump. But it's a better system with in tank pump and bypass reg IMO.
Old 02-08-2016, 07:59 PM   #23
65standard
65standard's Avatar
I'm sure you could just eliminate the in tank pump with a piece of hose. Then run the mechanical pump if you want.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 02-08-2016, 09:12 PM   #24
nascarmikeb
wow those pics make it look like a nice clean job
Ill start pricing it. So what are the advantages of using this type setup vs. old school mechanical?
Old 02-09-2016, 05:12 AM   #25
RodsGreen10
The advantages of the bypass style regulator
- Return style provides constant effective fuel pressure to the outlet port – pressure overage is bled off through the return port as needed.
- Constant effective fuel pressure enables fuel pressure to be set more accurately, and should remain constant regardless of load. It should be noted that the engine is not required to operate to accurately adjust fuel pressure, however, the fuel pump does need to be energized.
- Longer pump life and quieter pump operation as the pump is operating just hard enough to maintain pressure, instead of maintaining a higher as is the case of blocking style regulators.
