Will leaf spring load rating affect ride height?
Looking to replace the stock old rusty leaf springs on my 87 2wd Suburban.
My question: would a pair of springs rated at 3500lbs each make the rear sit higher than say a pair rated at 2500lbs?
![]() 1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
Diggin The SquareLife
Re: Will leaf spring load rating affect ride height?
Most likely any new leaf springs you put will raise it up
If it has the factory springs on it they have sagged over time.New oem springs will give you a little lift.The heavier springs will give you lift but can cause a stiffer ride tho.
