02-08-2016, 12:47 AM | #1 |
9 volts w/ CS144 and AAW 500560 harness
The attached diagram shows how i have my truck wired. With the key turned to the accessory postilion i have 12.5 volts at all circuits except the four I have circled. I have 9 volts at each of those fuses.
I get 14.5-14.75 volts while running at the battery. With the key switched to accessory If I remove the two wire plug at the back of the alternator I get the full 12.5 volts at the circuits in question. The brown wire has a 82 ohm 3 watt resistor soldered inline as required by this series of alternator. Any help is appreciated. I know I'm not being too detailed but wanted to post this up quickly. Thanks |
02-08-2016, 01:50 AM | #2 |
Re: 9 volts w/ CS144 and AAW 500560 harness
I have always used a diode not a resistor in place of the idiot light (6 amp/50 volt diode)
I dont see what the dashed brown wire is? is that the resistor? you do have the HOT in #2 on the back of alternator? https://www.google.com/search?q=10si...3ywtjKX9pqM%3A you may want to read this also http://www.jeepforum.com/forum/f8/de...e-what-990321/ Last edited by jtrichard; 02-08-2016 at 02:09 AM. |
02-08-2016, 03:11 AM | #3 | |
Thanks for the response. What I installed looks like what's shown in that Google link I may be calling it the wrong name. From what I gathered through this forum is that the stock dash light does not offer enough resistence to trigger the alt to charge. This was confirmed when the alternator started working after I had added the resistor/diode. My alt is wired just like your link shows. It has two wires. Brown running to the ignition and red to the post on the alternator itself. The dashed brown wire is a backup resistor wire in case the bulb blows out. I also just realized my attachment doesn't show where I circled. On the page showing the fuse panel the 4 fuse spots on the left of panel are the circuits I'm talking about. I'm trying to hook up a relay for the fan but 9 volts doesn't seem to be enough to trigger the relay. I cannot figure out why the alternator being connected would drop the voltage on the accessory side of the panel. Last edited by Joemomma1; 02-08-2016 at 03:33 AM. |
02-08-2016, 11:24 AM | #4 | |
What happens if you leave the alternator disconnected and place a load on any of those 4 fused accessory circuits? Does that cause the voltage to drop as well? If so, I'd suspect a problem with the ignition switch's accessory contacts. The CS alternators do require a minimum of 35Ω in the warning light / "exciter" circuit that is connected to their "L" terminal. So the 82Ω, 3W resistor you used should be plenty adequate. |
02-08-2016, 02:40 PM | #5 | |
While left unplugged from the alternator and a relay coneccted to one of those circuits the voltage drops from 12.5 to 9. When you say contacts do you mean internally? |
02-08-2016, 04:06 PM | #6 | |||
Msgt USAF Ret
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
02-08-2016, 04:42 PM | #7 | |
And yes, when I said contacts, I mean the electrical contacts inside the ignition switch. Specifically, the ones that power the accessory terminal. It sounds like they might not be making a very good connection, resulting in extra unwanted resistance that's causing the voltage drop. Under no-load conditions, there isn't any current flowing through the circuit to create a voltage drop across the extra resistance so you see full battery voltage. But as soon as you add a load (like the alternator exciter, relay, etc) it draws some current through that resistance, creating a voltage drop. |
02-09-2016, 05:49 PM | #8 |
Thanks to everyone that has posted here with help. Going on what was pointed to here, the ignition switch, I found the brown acc wire at the ignition switch was in the wrong spot on the harness which ended up feeding nothing. The acc terminal on the ignition switch was not connected to anything. After moving it everything is working as it should...for now. I had someone else install the kit and so far am finding a few things that have me questioning why I ever did that.
In regards to the efan, I have efan wire going to terminal 86 and 85 is to ground. terminal 30 is from the battery and 87 feeding a volvo two speed fan relay. I used 10ga. Why would I want it unfused? The diagram from AAW shows the fan being fed from that fused circuit. The attachment is in my first post to this thread. Thanks. |
02-09-2016, 09:51 PM | #9 | ||
Msgt USAF Ret
The IGN NUFUSED terminal on the fuse panel is just a power terminal controlled by the ignition switch. Anything using it for a power source needs to be fused separately. In the case of the fan relay power to 86, the relay should engage with very little current because the relay coil will close at a few milliamps. That's why most diagrams don't show it as a fused wire. The IGN UNFUSED terminal is often used as a power source for other accessories such as the HEI distributor and those may need to be fused ----------------------------------------------------------------------- Your finding on the key switch wiring makes a diagnosis almost impossible, and Ray and I were trying to account for the voltage drop that you showed. If you showed no feeds on the brown ACC wire I am puzzled as to how you showed any voltage at all I.E. 12 volts and 9 volts. Ray may be able to tell, but the only clue as we both said was resistance creating a voltage drop. Anyway I'm glad you got it resolved. If I can find it I'll post a good diagram of the fan wiring. Your PFD diagram is pretty hard to read but I down loaded it and enlarged it and I'm going to study it to see how they wired the relay. I didn't see the 86 power source so I'll look at it again. Cheers VV
02-09-2016, 10:31 PM | #10 | ||
Joemomma1, I'm glad to hear you found the problem.
Without knowing the details, it's hard to say for sure. But I wonder if that brown ACC feed wire was accidentally connected to one of the ignition switch GND terminals along with the wire for the brake warning (or temp) light bulb check. Since that bulb is hooked to IGN+ and it's "ground" side is "floating" (when the switches are open), the bulb filament would act as a "pull up" resistor, bringing that brown wire up to battery voltage under no load conditions and likely allowing it to drop to 9V under a small load. Again, that's just a guess on my part to possibly explain those voltage readings. |
02-10-2016, 01:32 AM | #11 | |
I see what you mean now but this kit came with a dedicated fused circuit for the fan. Their diagram shows it as the power feed but I'm using it for the coil circuit of the relay and powering the fan straight from the battery. I can't see why there was any voltage on the accessory side but will study the diagram. |
02-10-2016, 04:08 PM | #12 |
Have u thought about just powering the Volvo relay under hood instead. I don't agree with making the fuse panel under dash an incoming voltage bussbar then sending high current back out again....
02-11-2016, 02:32 AM | #13 |
Thanks for the reply and I'm right there with you. I must not be very clear at describing what I'm doing but I have it wired as you suggested. I'm only using the wire from the fuse panel for the coil side of a relay feeding the Volvo relay. The AAW diagram shows it as the power source for the fan though. I wanted it to be switched so it will not keep running when I turn the truck off. It's tough to make heads and tails of the photo but the Volvo relay is attached to the battery tray. I tried to keep it as clean and as close to the battery as possible.
02-11-2016, 03:03 AM | #14 |
Ok....sometimes it makes you wonder if AAW even builds actual vehicles to test the latest trends ya know?
At any rate, the factory Volvos (and me as well) use an IGN control relay to feed power to the Volvo relay-its this reason why I wonder the reasoning behind Painless and AAW supplying a 10ga IGN switched 12V fan lead. I wouldn't suggest running a switched IGN source for electric fans solely through the IGN switch circuit-it will get warm. The relays I use are 80A rated mainly because I prefer to use oversized input/output terminals for high current devices such as electric fans So I take it you're using a 2-speed fan(s)? What type are you running off that Volvo relay? Are you using a dual temp switch or (2) separate temp switches? |
02-11-2016, 11:40 PM | #15 | |
80A relay?! Wow. It's hooked up with a 30A and hasn't popped yet while I've been testing it. I'm using a two speed Taurus fan in and an Audi dual temp switch installed on the thermostat housing. Do you recommend 80A on all efans? Could I be starving the motor? |
02-12-2016, 07:11 AM | #16 |
I don't think you'll have any issues as long as you're using a quality relay-I simply like to use a relay rated @ twice the max amp draw the fan will ever see. It may be slightly overkill but I know the relay isn't working super hard this way....ya know?
02-12-2016, 10:51 AM | #17 |
Saw this thread as I am working on my AAW 500560 as well. Glad you figured your problem out. I am troubleshooting as well.
02-13-2016, 02:05 AM | #18 |
After looking at the diagrams and instructions again I was incorrect. They did exactly as you said making the panel a buss bar. The 10ga wire is not shown on the complete harness diagram but on the individual page regarding the headlamp harness it is shown. I didn't notice this before as that wire is now being used for the headlight relays.
02-13-2016, 09:38 AM | #19 |
Ok...that makes a bit more sense then. So, are you still reading only 9V @ the inside fuseblock?
02-17-2016, 02:27 AM | #20 |
