72 to 73 Crossmember??
Will the 72 auto trans crossmember work with the 73 up frame? Looks like i might have to do some drilling but the length is correct and the trans mount holes are in the right spot. My concern is if the trans tail shaft will be sitting at the same level from the ground or will it change the angle? Thanks
