Help regardig RH LH Glass install
Hello All,
I have a 1971 C10 LB and have been working on the seals lately. I read through the forums and cant seem to find the answer for a few questions... First issue The gent I bought the truck from took everything apart and separated the window from the steel piece. I am uncertain what I should use to "glue" the window back in to the metal piece? Second issue There seems to be a gap between the driver window and the new seal I installed. I thought and tried to shim the track for the front (wing window) and its seemed to moved things forward a bit, but I am worried about getting rust inside my doors over time. Any help would be greatly appreciated. Thanks Joe |
| Bookmarks |
